[postgis-tickets] [PostGIS] #4426: Travis is broken for stable branches (2.4 and 2.5)
trac at osgeo.org
Wed Jun 12 06:21:44 PDT 2019
Reporter: Algunenano | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: Management 2.0
Component: build/upgrade/install | Version: 2.3.x
Keywords: |
11.51s$ sudo apt-get update -qq
W: The repository 'http://archive.ubuntu.com/ubuntu artful Release' does
not have a Release file.
W: GPG error: https://packagecloud.io/github/git-lfs/ubuntu trusty
InRelease: The following signatures couldn't be verified because the
public key is not available: NO_PUBKEY 6B05F25D762E3157
W: The repository 'https://packagecloud.io/github/git-lfs/ubuntu trusty
InRelease' is not signed.
W: There is no public key available for the following key IDs:
6B05F25D762E3157
W:
http://ppa.launchpad.net/couchdb/stable/ubuntu/dists/trusty/Release.gpg:
Signature by key 15866BAFD9BCC4F3C1E0DFC7D69548E1C17EAB57 uses weak digest
algorithm (SHA1)
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/artful/main
/binary-amd64/Packages 404 Not Found [IP: 91.189.88.161 80]
E: Failed to fetch
http://archive.ubuntu.com/ubuntu/dists/artful/main/binary-i386/Packages
E: Failed to fetch
http://archive.ubuntu.com/ubuntu/dists/artful/restricted/binary-
E: Failed to fetch
http://archive.ubuntu.com/ubuntu/dists/artful/restricted/binary-i386/Packages
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/artful/universe
E: Some index files failed to download. They have been ignored, or old
ones used instead.
The command "sudo apt-get update -qq" failed and exited with 100 during .
We have to either look for different packages or migrate those branches to
use Docker too.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4426>
