[postgis-tickets] r17516 - Fix travis build
Raul
raul at rmr.ninja
Wed Jun 12 08:27:01 PDT 2019
Author: algunenano
Date: 2019-06-12 08:27:01 -0700 (Wed, 12 Jun 2019)
New Revision: 17516
branches/2.5/.travis.yml
branches/2.5/libpgcommon/gserialized_gist.h
branches/2.5/postgis/gserialized_gist_nd.c
Fix travis build
Closes #4426
Modified: branches/2.5/.travis.yml
--- branches/2.5/.travis.yml 2019-06-12 14:04:41 UTC (rev 17515)
+++ branches/2.5/.travis.yml 2019-06-12 15:27:01 UTC (rev 17516)
@@ -7,13 +7,9 @@
addons:
postgresql: "9.6"
- apt:
- packages:
- - eatmydata
before_install:
- eval "${MATRIX_EVAL}"
- - sudo sh -c "echo /usr/lib/libeatmydata/libeatmydata.so >> /etc/ld.so.preload"
- curl -sSfL https://github.com/mapbox/logbt/archive/v2.0.3.tar.gz | sudo tar --gunzip --extract --strip-components=1 --exclude="*md" --exclude="test*" --directory=/usr/local
- curl -sSfL https://raw.githubusercontent.com/mapbox/logbt/30c554dd37b6c96c23fc424f75910fc6d6696f00/bin/logbt | sudo tee /usr/local/bin/logbt > /dev/null
- sudo logbt --setup
@@ -27,7 +23,7 @@
- sudo apt-get update -qq
- mkdir -p /home/travis/deb && touch /home/travis/deb/__ && sudo cp -n /home/travis/deb/* /var/cache/apt/archives || true
- sudo apt-get install -y --allow-unauthenticated --no-install-recommends --no-install-suggests libsfcgal1 libsfcgal-dev postgresql-server-dev-9.6 libxml2-utils libcunit1-dev xsltproc docbook-xsl docbook-mathml dblatex libgeos-dev libjson0-dev libgdal-dev gdb libc6-dbg
- - sudo sh -c "echo deb http://archive.ubuntu.com/ubuntu/ artful main restricted universe multiverse >> /etc/apt/sources.list"
+ - sudo sh -c "echo deb http://archive.ubuntu.com/ubuntu/ bionic main restricted universe multiverse >> /etc/apt/sources.list"
- sudo apt-get install -y --allow-unauthenticated --no-install-recommends --no-install-suggests binutils libproj-dev libprotobuf-c-dev protobuf-c-compiler
- cp -n /var/cache/apt/archives/* /home/travis/deb || true
@@ -45,7 +41,7 @@
compiler: gcc
-dist: trusty
+dist: xenial
cache:
ccache: true
Modified: branches/2.5/libpgcommon/gserialized_gist.h
--- branches/2.5/libpgcommon/gserialized_gist.h 2019-06-12 14:04:41 UTC (rev 17515)
+++ branches/2.5/libpgcommon/gserialized_gist.h 2019-06-12 15:27:01 UTC (rev 17516)
@@ -147,6 +147,7 @@
bool box2df_overabove(const BOX2DF *a, const BOX2DF *b);
+void gidx_validate(GIDX *b);
bool gidx_contains(GIDX *a, GIDX *b);
int gserialized_datum_get_box2df_p(Datum gsdatum, BOX2DF *box2df);
Modified: branches/2.5/postgis/gserialized_gist_nd.c
--- branches/2.5/postgis/gserialized_gist_nd.c 2019-06-12 14:04:41 UTC (rev 17515)
+++ branches/2.5/postgis/gserialized_gist_nd.c 2019-06-12 15:27:01 UTC (rev 17516)
@@ -133,19 +133,19 @@
/* Ensure all minimums are below maximums. */
-static inline void gidx_validate(GIDX *b)
+void
+gidx_validate(GIDX *b)
uint32_t i;
Assert(b);
- POSTGIS_DEBUGF(5,"validating gidx (%s)", gidx_to_string(b));
- for ( i = 0; i < GIDX_NDIMS(b); i++ )
+ POSTGIS_DEBUGF(5, "validating gidx (%s)", gidx_to_string(b));
+ for (i = 0; i < GIDX_NDIMS(b); i++)
- if ( GIDX_GET_MIN(b,i) > GIDX_GET_MAX(b,i) )
+ if (GIDX_GET_MIN(b, i) > GIDX_GET_MAX(b, i))
- float tmp;
- tmp = GIDX_GET_MIN(b,i);
- GIDX_SET_MIN(b,i,GIDX_GET_MAX(b,i));
- GIDX_SET_MAX(b,i,tmp);
+ float tmp = GIDX_GET_MIN(b, i);
+ GIDX_SET_MIN(b, i, GIDX_GET_MAX(b, i));
+ GIDX_SET_MAX(b, i, tmp);
return;
