[postgis-tickets] [PostGIS] #4428: debbie-docker move to new disk
PostGIS trac at osgeo.org
Thu Jun 13 09:22:43 PDT 2019
  Reporter:  robe        |      Owner:  robe
      Type:  defect      |     Status:  closed
  Priority:  medium      |  Milestone:  Management 2.0
 Component:  management  |    Version:  trunk
Resolution:  fixed       |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Old description:
> We have a lot of fat docker images for postgis, geos, geos-php which was
> eating up a lot of space so was down to 4 GB on the partition I had
> alotted for lxd zfs.
> That said I created a new 500GB disk zfs partition and moved debbie
> docker to that.
> I'll write the steps in
> https://git.osgeo.org/gitea/postgis/postgis-servers
> once I've figured the best place to put it, for now here are my scribbled
> notes:
New description:
 That said I created a new 250GB disk zfs partition and moved debbie docker
 to that.
 notes:
Comment:
 My scribbled notes
 Attach to host.postgis.net
 https://www.atlantic.net/community/howto/configuring-block-storage-linux-
 servers/
 #Go back into to server
 ls /dev/disk/by-id/scsi-0AN_Volume_*
 should output -  /dev/disk/by-id/scsi-0AN_Volume_postgis_storage
 #now install gdisk to help setting up
 apt install gdisk
 gdisk /dev/disk/by-id/scsi-0AN_Volume_postgis_storage
 Command (? or help):  n  #this will create a new partition taking up whole
 drive
 take remaining defualts by clicking enter
 When hit the next:
 Command (? or help): p  #this will print the disk layout
 When hit the next:
 Command (? or help): w  #saves the partition
 Y to confirm
 #now add new pool to existing lxd
 #upgrade to larger disk
 http://genetics.wustl.edu/technology/replacing-a-bad-zfs-drive-with-
 larger-drive/
 #create on existing zfs and add to lxd
 zpool create -f lxd2 /dev/disk/by-id/scsi-0AN_Volume_postgis_storage
 lxc storage create pool2 zfs source=lxd2
 #move containers to new pool
 https://blog.bilak.info/2018/07/08/moving-lxd-containers-from-one-pool-to-
 another/
 #move debbie-docker to new pool
 lxc exec debbie-docker bash
 #in debbie-docker
 shutdown -P -H now
 lxc storage list #confirm in use
 lxc cp debbie-docker debbie-docker-moved -s=pool2
 #rename original container
 lxc mv debbie-docker debbie-docker-to-delete
 #move new back to old name and cofirm good by starting
 # rename container back for sanity ;)
 lxc mv debbie-docker-moved debbie-docker
 lxc start debbie-docker
 lxc move some_container-moved some_container
 # if you want to move instead do
 # move container to pool2
 lxc mv some-container some-container-moved -s=pool2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4428#comment:1>
