[postgis-tickets] r17531 - set defaults back to old and put projdir back in configure for some reason not picking up proj
Regina Obe
lr at pcorp.us
Thu Jun 13 04:54:32 PDT 2019
Author: robe
Date: 2019-06-13 16:54:32 -0700 (Thu, 13 Jun 2019)
New Revision: 17531
trunk/ci/winnie/build_postgis.sh
trunk/ci/winnie/package_postgis.sh
trunk/ci/winnie/regress_postgis.sh
Modified: trunk/ci/winnie/build_postgis.sh
--- trunk/ci/winnie/build_postgis.sh 2019-06-13 14:54:46 UTC (rev 17530)
+++ trunk/ci/winnie/build_postgis.sh 2019-06-13 23:54:32 UTC (rev 17531)
@@ -1,14 +1,16 @@
#!/bin/bash
set -e
if [[ "${OVERRIDE}" == '' ]] ;
+ export SFCGAL_VER=1.3.2
+ export GEOS_VER=3.7.1
+ export GDAL_VER=2.2.4
+ export PROJ_VER=4.9.3
+ export PCRE_VER=8.33
+ export PROTOBUF_VER=3.2.0
+ export PROTOBUFC_VER=1.2.1
+ export CGAL_VER=4.11
export GEOS_VER=3.8
- export GDAL_VER=2.4.1
- export PROJ_VER=6.1.0
- export SFCGAL_VER=1.3.2
- export PROTOBUF_VER=3.2.0
- export PROTOBUFC_VER=1.2.1
- export CGAL_VER=4.11
- export ICON_VER=1.15
fi;
@@ -68,7 +70,7 @@
#add protobuf
export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-export PKG_CONFIG_PATH=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig;
+#export PKG_CONFIG_PATH=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig;
echo PATH AFTER: $PATH
@@ -120,6 +122,7 @@
--with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
--with-gui --with-gettext=no \
--with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
+ --with-projdir=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE} \
--without-interrupt-tests \
--prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE}
else
@@ -132,6 +135,7 @@
--with-pgconfig=${PGPATH}/bin/pg_config \
--with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/geos-config \
--with-libiconv=${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE} \
Modified: trunk/ci/winnie/package_postgis.sh
--- trunk/ci/winnie/package_postgis.sh 2019-06-13 14:54:46 UTC (rev 17530)
+++ trunk/ci/winnie/package_postgis.sh 2019-06-13 23:54:32 UTC (rev 17531)
@@ -16,8 +16,8 @@
#otherwise use the ones jenkins passes thru
export GEOS_VER=3.8
Modified: trunk/ci/winnie/regress_postgis.sh
--- trunk/ci/winnie/regress_postgis.sh 2019-06-13 14:54:46 UTC (rev 17530)
+++ trunk/ci/winnie/regress_postgis.sh 2019-06-13 23:54:32 UTC (rev 17531)
@@ -2,8 +2,8 @@
set -e
if [[ "${OVERRIDE}" == '' ]] ; then
export GEOS_VER=3.8
@@ -120,6 +120,7 @@
else
@@ -132,6 +133,7 @@
