[postgis-tickets] [PostGIS] #4372: PROJ 6: 4x slowdown on indexes over ST_Transform
PostGIS trac at osgeo.org
Fri Jun 14 06:11:17 PDT 2019
  Reporter:  Algunenano  |      Owner:  Algunenano
      Type:  defect      |     Status:  assigned
  Priority:  high        |  Milestone:  PostGIS 3.0.0
 Component:  postgis     |    Version:  trunk
Resolution:              |   Keywords:
Comment (by Algunenano):
 If I remove the call to `SetPROJLibPath` to avoid the calls to
 `proj_context_set_search_paths` the error messages disappear, but what
 used to be 1.8s with PROJ 5.2 or 7.6s with PROJ6 before this change now
 becomes 20x slower: 116.2secs.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4372#comment:6>
