[postgis-tickets] [PostGIS] #4430: PostGIS bundle fails in silent install mode for PostgreSQL 11.2
PostGIS trac at osgeo.org
Mon Jun 17 01:47:50 PDT 2019
 Reporter:  danielheden     |      Owner:  pramsey
     Type:  defect          |     Status:  new
 Priority:  medium          |  Milestone:  PostGIS PostgreSQL
Component:  postgis         |    Version:  2.5.x
 Keywords:  silent install  |
 Trying to install PostGIS using the bundle installer (postgis-bundle-
 pg11x64-setup-2.5.2-1.exe), the one stackbuilder downloads.
 The error message it gives is "PostGIS has to be installed to the
 PostgreSQL folder."
 The problem seems to be that the installer locks for
 %ProgramFiles%\PostgreSQL\11 instead of %ProgramFiles%\PostgreSQL\11.2
 I run with parameters: /S /USERNAME=postgres /PASSWORD=xxxxxx /PORT=5432
 And we have been using the same parameter for installing for several
 year’s without problem before.
 The installer works if NOT run in silent mode.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4430>
