[postgis-tickets] [PostGIS] #4372: PROJ 6: 4x slowdown on indexes over ST_Transform
trac at osgeo.org
Mon Jun 17 04:27:46 PDT 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by Algunenano):
I have a WIP in https://github.com/postgis/postgis/pull/422 to address
some of the issues found here.
The main fix to gain the performance back is to also cache the
proj_crs_is_swapped calls to avoid making them in every ST_Transform call.
I'm still investigating further to try to understand why removing the
invalid set_searchpath makes some calls 10x slower with PROJ6. Also I need
to review that I haven't broken anything in proj5 ^^
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4372#comment:8>
