[postgis-tickets] [PostGIS] #4372: PROJ 6: 4x slowdown over points
trac at osgeo.org
Mon Jun 17 07:45:26 PDT 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by Algunenano):
Digging deeper: these are the functions affected by the slowdown (apart
from transform, which is fixed by one of my patches):
- `TWKBFromLWGEOM`.
- `TWKBFromLWGEOMArray`.
- `geography_in` / `geography_from_text` / `geography_from_geometry` /
`geography_from_geometry` / `geography_recv` / `geography_typmod_in` as
they call `srid_check_latlong`.
- `geography_centroid` / `geography_distance_knn` /
`geography_distance_uncached` / `geography_distance` / `geography_dwithin`
/ `geography_distance_tree` / `geography_dwithin_uncached` /
`geography_area` / `geography_perimeter` / `geography_length` /
`geography_project` / `geography_azimuth` as they call
`spheroid_init_from_srid`.
An example with the same query using ST_AsTWKB: 404ms in PROJ5 vs 1230ms
in PROJ6.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4372#comment:10>
