[postgis-tickets] [PostGIS] #4372: PROJ 6: 4x slowdown over points
trac at osgeo.org
Wed Jun 19 08:26:37 PDT 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by Raul Marin):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"17548" 17548]:
#!CommitTicketReference repository="" revision="17548"
PROJ cache: Improve the eviction process
Instead of selecting a projection that doesn't match
the input source srid and silently drop all cache elements
after it (potentially dropping the whole cache), we keep
a count to know how many item each element has been used
and only drop the element with less uses.
Closes #4372
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4372#comment:18>
