[postgis-tickets] r17550 - Ensure sql and expected dirs are created when needed
Sandro Santilli strk at kbt.io
Thu Jun 20 12:08:13 PDT 2019
Author: strk
Date: 2019-06-20 00:08:13 -0700 (Thu, 20 Jun 2019)
New Revision: 17550
   branches/2.3/extensions/postgis_tiger_geocoder/Makefile.in
See https://dronie.osgeo.org/postgis/postgis/311/3/2
Modified: branches/2.3/extensions/postgis_tiger_geocoder/Makefile.in
--- branches/2.3/extensions/postgis_tiger_geocoder/Makefile.in	2019-06-19 16:57:22 UTC (rev 17549)
+++ branches/2.3/extensions/postgis_tiger_geocoder/Makefile.in	2019-06-20 07:08:13 UTC (rev 17550)
@@ -30,7 +30,7 @@
 PG91         = $(shell $(PG_CONFIG) --version | $(GREP) -qE " 8\.| 9\.0" && echo no || echo yes)
 SQL_BITS     = $(wildcard sql_bits/*.sql)
-EXTRA_CLEAN += sql/*.sql ${SQL_BITS}
+EXTRA_CLEAN += sql/*.sql ${SQL_BITS}
 #test address standardizer if also built
 ifeq (@ADDRESS_STANDARDIZER@,address_standardizer)
@@ -41,55 +41,49 @@
 ifeq ($(PG91),yes)
 all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql  sql_minor_upgrade sql/test-normalize_address.sql  sql/test-pagc_normalize_address.sql expected/test-normalize_address.out expected/test-pagc_normalize_address.out sql/test-upgrade.sql expected/test-upgrade.out sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql  sql_minor_upgrade
-sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql
-	mkdir -p sql
-	mkdir -p expected
+expected sql:
+	mkdir -p $@
+sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | expected sql
 	cp $< $@
-expected/test-normalize_address.out: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/normalize_address_regress
-	mkdir -p expected
+expected/test-normalize_address.out: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/normalize_address_regress | expected
 	cat $^ > $@
-expected/test-pagc_normalize_address.out: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/pagc_normalize_address_regress
+expected/test-pagc_normalize_address.out: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/pagc_normalize_address_regress | expected
 	cat $^ > $@
 ## adding \t .. to force output to be the same as what get in regular regress in tiger folder
-sql/test-normalize_address.sql: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/normalize_address_regress.sql
-	mkdir -p sql
+sql/test-normalize_address.sql: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/normalize_address_regress.sql | sql
 	cat $^ > $@
-sql/test-upgrade.sql:
-	mkdir -p sql
+sql/test-upgrade.sql: | sql
 	echo 'ALTER EXTENSION ${EXTENSION} UPDATE TO "$(EXTVERSION)next"' > $@
-expected/test-upgrade.out: sql/test-upgrade.sql
+expected/test-upgrade.out: sql/test-upgrade.sql | expected
 	cp $< $@
-sql/test-pagc_normalize_address.sql: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/pagc_normalize_address_regress.sql
-	mkdir -p sql
+sql/test-pagc_normalize_address.sql: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/pagc_normalize_address_regress.sql | sql
 	cat $^ > $@
-sql/$(EXTENSION).sql: sql_bits/tiger_geocoder.sql  sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql
-	mkdir -p sql
+sql/$(EXTENSION).sql: sql_bits/tiger_geocoder.sql  sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql | sql
 	cat $^ > $@
 #this is a cludge to allow upgrading from same SVN to same SVN
-sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql: ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/tiger_geocoder_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql
-	mkdir -p sql
+sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql: ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/tiger_geocoder_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql | sql
 	cat $^ > $@
 	echo "SELECT postgis_extension_drop_if_exists('${EXTENSION}', 'DROP SCHEMA tiger_data');" >> $@
 	cat ../postgis_extension_helper_uninstall.sql  >> $@
-sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql: sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql
-	mkdir -p sql
+sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql: sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql | sql
 	cp $< $@
 #strip BEGIN/COMMIT since these are not allowed in extensions
-#strip CREATE SCHEMA since we force extension
+#strip CREATE SCHEMA since we force extension
 # to create schema by setting schema to tiger_geocoder in control
 #also remove tiger_data from extension if it is part of it
 sql_bits/tiger_geocoder_minor.sql.in: ../../extras/tiger_geocoder/utility/set_search_path.sql \
@@ -123,7 +117,7 @@
 	../../extras/tiger_geocoder/geocode/reverse_geocode.sql \
 	../../extras/tiger_geocoder/geocode/census_tracts_functions.sql
 	cat $^ > $@
 #also remove tiger_data from extension if it is part of it so data gets backed up
 sql_bits/tiger_geocoder.sql.in: sql_bits/norm_addy_create.sql.in \
@@ -164,20 +158,20 @@
 	cat $^ > $@
 sql_bits/tiger_geocoder.sql: sql_bits/tiger_geocoder.sql.in
 	sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' -e '/^CREATE SCHEMA/d;'  $< > $@
 	$(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
 sql_bits/add_search_path.sql: sql_bits/add_search_path.sql.in
 	cp $< $@
 ../../doc/tiger_geocoder_comments.sql:
 	$(MAKE) -C ../../doc comments
 sql_bits/tiger_geocoder_comments.sql: ../../doc/tiger_geocoder_comments.sql
 	cp $< $@
 #grep all lines that start with CREATE OR REPLACE FUNCTION, TRIGGER...
 #then replace CREATE OR REPLACE .. with ALTER EXTENSION..;
 #then remove default values and extra junk
@@ -192,33 +186,31 @@
 # 		-e 's/\\(;/;/' \
 # 		-e 's/;;/;/g' $< > $@
-#hardcode for now using
+#hardcode for now using
 #the extensions/make_unpackaged.sql script form an install
-sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql_bits/tiger_geocoder--unpackaged.sql.in
-	mkdir -p sql
+sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql_bits/tiger_geocoder--unpackaged.sql.in | sql
 	cp $< $@
 #upgrade script should have everything but table, schema, type creation/alter
 #NOTE: we assume all object definitions end in ;
 #first expression deletes all non-removable objects defined on same line
-#second deletes all non-removable defined on multiple lines
+#second deletes all non-removable defined on multiple lines
 #  the end of the body of object we assume ends in ;
-#aggregates are special
+#aggregates are special
 #they can be dropped but we need to remove
 #them from the extension first
-sql/tiger_geocoder_upgrade_minor.sql:  sql_bits/tiger_geocoder_minor.sql.in
-	mkdir -p sql
+sql/tiger_geocoder_upgrade_minor.sql:  sql_bits/tiger_geocoder_minor.sql.in | sql
 	 sed -e '/^\(CREATE\|ALTER\) \(CAST\|TYPE\|TABLE\|SCHEMA\|DOMAIN\|TRIGGER\).*;/d' \
 	 	 -e '/^\(CREATE\|ALTER\) \(CAST\|TYPE\|TABLE\|SCHEMA\|DOMAIN\|TRIGGER\)/,/\;/d' \
 	 	 -e 's/BEGIN;//g' -e 's/COMMIT;//g' \
 sql_minor_upgrade: sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql
 	for OLD_VERSION in $(UPGRADEABLE_VERSIONS); do \
   	  cat $^ > sql/$(EXTENSION)--$$OLD_VERSION--$(EXTVERSION).sql; \
 	done
-#only extension files
+#only extension files
 DATA = ${EXTENSION}.control sql/$(EXTENSION).sql $(wildcard sql/*--*.sql)
 EXTRA_CLEAN += $(wildcard expected/*--*.out)
 EXTRA_CLEAN += sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql
