[postgis-tickets] [PostGIS] #3437: ST_Intersects incorrect for MultiPoints
PostGIS trac at osgeo.org
Fri Jun 21 03:40:09 PDT 2019
  Reporter:  dbaston   |      Owner:  dbaston
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS GEOS
 Component:  postgis   |    Version:  2.2.x
Resolution:            |   Keywords:
Comment (by Algunenano):
 > After GEOS 3.6 is released, consider re-enabling PreparedIntersects? for
 Points/MultiPoints? if there is a performance benefit.
 I've just tested it:
 Current trunk:
 template_postgis=# WITH
 a AS (SELECT ST_Collect(ST_MakePoint(random(), random())) as geom from
 generate_series(1, 1000)),
 b AS (SELECT (ST_Dump(geom)).geom FROM a)
 SELECT count(*) FROM b INNER JOIN a ON ST_Intersects(a.geom, b.geom);
  count
   1000
 (1 row)
 Time: 2366.630 ms (00:02.367)
  count
   1000
 (1 row)
 Time: 2355.091 ms (00:02.355)
  count
   1000
 (1 row)
 Time: 2344.796 ms (00:02.345)
 Removing the patch since GEOS 3.6 is now the minimum requirement:
  count
   1000
 (1 row)
 Time: 89.477 ms
  count
   1000
 (1 row)
 Time: 81.209 ms
  count
   1000
 (1 row)
 Time: 78.410 ms
  count
   1000
 (1 row)
 Time: 82.055 ms
 It's a nice 30x that we have there. I'll remove it now :D
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3437#comment:6>
