[postgis-tickets] [PostGIS] #4432: Unable to upgrade procedures from 11 to 12 flavour
trac at osgeo.org
Sat Jun 22 18:10:03 PDT 2019
Reporter: komzpa | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: 2.4.x
Resolution: | Keywords:
Comment (by robe):
Did you have postgis_topology and postgis_tiger_geocoder installed before
hand? I would think those errors would only happen if you had
postgis_topology and postgis_tiger_geocoder installed and for some reason
you didn't have them available in your new version.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4432#comment:3>
