[postgis-tickets] [PostGIS] #4440: Type Lookups in FDW fail
    trac at osgeo.org
    Thu Jun 27 11:25:49 PDT 2019
 Reporter:  pramsey   |      Owner:  pramsey
     Type:  defect    |     Status:  assigned
 Priority:  critical  |  Milestone:  PostGIS 2.5.3
Component:  postgis   |    Version:  2.5.x
 Keywords:            |
 https://dba.stackexchange.com/questions/240718/querying-foreign-table-
 with-sp-gist-index-results-in-error-cache-lookup-failed?rq=1
 Because FDW connections have very sparse search_path, it's common for
 calls to TypenameGetTypid() to fail. A different way of looking up the
 PostGIS type Oid numbers needs to be used.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4440>
