[postgis-tickets] r17563 - add more pkgconfig and make zlib	swappable
    Regina Obe
    lr at pcorp.us
    Thu Jun 27 01:15:29 PDT 2019
Author: robe
Date: 2019-06-27 13:15:29 -0700 (Thu, 27 Jun 2019)
New Revision: 17563
   trunk/ci/winnie/build_postgis.sh
   trunk/ci/winnie/package_postgis.sh
   trunk/ci/winnie/regress_postgis.sh
Modified: trunk/ci/winnie/build_postgis.sh
--- trunk/ci/winnie/build_postgis.sh	2019-06-27 14:15:38 UTC (rev 17562)
+++ trunk/ci/winnie/build_postgis.sh	2019-06-27 20:15:29 UTC (rev 17563)
@@ -11,11 +11,20 @@
   export PROTOBUFC_VER=1.2.1
   export CGAL_VER=4.11
 	export GEOS_VER=3.8
+  export ZLIB_VER=1.2.11
 fi;
+#set to something even if override is on but not set
+if  [[ "${ZLIB_VER}" == '' ]] ; then
+fi;
 export PCRE_VER=8.33
-export LIBXML_VER=2.7.8
+if  [[ "${LIBXML_VER}" == '' ]] ; then
+  export LIBXML_VER=2.7.8
+fi;
 #export GDAL_VER=2.4.0
 export PROJECTS=/projects
@@ -66,7 +75,7 @@
 export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
 #PATH="${MINGPROJECTS}/gettext/rel-gettext-0.18.1/bin:${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtk/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}/bin:${PATH}"
-PATH="${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
+PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
 #add protobuf
 export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
@@ -97,7 +106,7 @@
     export PATH="${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
 fi
-export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig ${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig"
 if [ -n "$SFCGAL_VER" ]; then
Modified: trunk/ci/winnie/package_postgis.sh
--- trunk/ci/winnie/package_postgis.sh	2019-06-27 14:15:38 UTC (rev 17562)
+++ trunk/ci/winnie/package_postgis.sh	2019-06-27 20:15:29 UTC (rev 17563)
@@ -26,8 +26,19 @@
 fi;
+fi;
+export PCRE_VER=8.33
+fi;
 export MINGPROJECTS=/projects
 export PATHOLD=$PATH
Modified: trunk/ci/winnie/regress_postgis.sh
--- trunk/ci/winnie/regress_postgis.sh	2019-06-27 14:15:38 UTC (rev 17562)
+++ trunk/ci/winnie/regress_postgis.sh	2019-06-27 20:15:29 UTC (rev 17563)
@@ -9,9 +9,22 @@
 	export ICON_VER=1.15
 fi;
+fi;
+fi;
 #export PROJ_VER=5.2.0
@@ -56,7 +69,6 @@
   fi;
 fi;
 #export POSTGIS_SRC=${PROJECTS}/postgis/trunk
 export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
@@ -95,9 +107,10 @@
 fi
 	##hard code versions of cgal etc. for now
