[postgis-tickets] r17566 - Fix wagyu configure dropping CPPFLAGS
Raul raul at rmr.ninja
Fri Jun 28 08:39:05 PDT 2019
Author: algunenano
Date: 2019-06-28 08:39:05 -0700 (Fri, 28 Jun 2019)
New Revision: 17566
   trunk/NEWS
   trunk/configure.ac
Closes #4443
Modified: trunk/NEWS
--- trunk/NEWS	2019-06-28 10:00:18 UTC (rev 17565)
+++ trunk/NEWS	2019-06-28 15:39:05 UTC (rev 17566)
@@ -17,6 +17,7 @@
   - #4372, PROJ6: Speed improvements (Raúl Marín)
   - #3437, Speed up ST_Intersects with Points (Raúl Marín)
   - #4438, Update serialization to support extended flags area (Paul Ramsey)
+  - #4443, Fix wagyu configure dropping CPPFLAGS (Raúl Marín)
 PostGIS 3.0.0alpha2
 2019/06/02
@@ -183,7 +184,7 @@
   - #4327, Avoid pfree'ing the result of getenv (Raúl Marín)
   - #4406, Throw on invalid characters when decoding geohash (Raúl Marín)
   - #4394, Allow FULL OUTER JOIN on geometry (Darafei Praliaskouski)
-  - #4441, Make GiST penalty friendly to multi-column indexes and build single-column
+  - #4441, Make GiST penalty friendly to multi-column indexes and build single-column
            ones faster. (Darafei Praliaskouski)
Modified: trunk/configure.ac
--- trunk/configure.ac	2019-06-28 10:00:18 UTC (rev 17565)
+++ trunk/configure.ac	2019-06-28 15:39:05 UTC (rev 17566)
@@ -1483,7 +1483,7 @@
             CC_SAVE="$CC"
             CFLAGS_SAVE="$CFLAGS"
             CXXFLAGS_SAVE="$CXXFLAGS"
-            CPPFLAGS_SAVE="$CPPFLAGS_SAVE"
+            CPPFLAGS_SAVE="$CPPFLAGS"
             WAGYU_CXX=`"$PG_CONFIG" --cc`
             CPPFLAGS="-x c++"
