[postgis-tickets] [PostGIS] #4407: Test failure on 32bit: tickets ... #3719
trac at osgeo.org
Fri Jun 28 13:05:16 PDT 2019
Reporter: myon | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
I should add on 32-bit testing with GEOS 3.8 head and freebsd 32-bit is at
GEOS: 3.6.3-CAPI-1.10.3 80c13047
So could still be an issue with GEOS 3.7.1 (and 32-bit). I'll try to do a
32-bit test on windows to try to replicate.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4407#comment:9>
