[postgis-tickets] [PostGIS] #4394: FULL JOIN on geometry not supported
PostGIS trac at osgeo.org
Fri Jun 28 15:28:01 PDT 2019
  Reporter:  komzpa   |      Owner:  pramsey
      Type:  defect   |     Status:  reopened
  Priority:  medium   |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 okay I'm a bit disappointed the more common case of
  with mj as (select 'POINT(0 0)'::geometry geom) select '#4394', b.geom As
 b_geom, a.geom As a_geom from mj a full join mj b on ST_Intersects(a.geom,
 b.geom);
 Does not work.  Could it work? or is this the best we can do.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4394#comment:4>
