[postgis-tickets] r17570 - more changes to allow custom building of version items
Regina Obe
lr at pcorp.us
Sun Jun 30 06:27:28 PDT 2019
Author: robe
Date: 2019-06-30 18:27:27 -0700 (Sun, 30 Jun 2019)
New Revision: 17570
trunk/ci/winnie/build_postgis.sh
trunk/ci/winnie/package_postgis.sh
trunk/ci/winnie/regress_postgis.sh
Modified: trunk/ci/winnie/build_postgis.sh
--- trunk/ci/winnie/build_postgis.sh 2019-06-28 18:03:24 UTC (rev 17569)
+++ trunk/ci/winnie/build_postgis.sh 2019-07-01 01:27:27 UTC (rev 17570)
@@ -1,37 +1,51 @@
#!/bin/bash
set -e
if [[ "${OVERRIDE}" == '' ]] ; then
- export SFCGAL_VER=1.3.2
- export GEOS_VER=3.7.1
- export GDAL_VER=2.2.4
- export PROJ_VER=4.9.3
- export PCRE_VER=8.33
- export PROTOBUF_VER=3.2.0
- export PROTOBUFC_VER=1.2.1
- export CGAL_VER=4.11
export GEOS_VER=3.8
- export ZLIB_VER=1.2.11
+ export GDAL_VER=2.2.4
+ export PROJ_VER=4.9.3
+ export SFCGAL_VER=1.3.2
+ export CGAL_VER=4.11
+ export ICON_VER=1.15
+ export ZLIB_VER=1.2.11
+ export PROTOBUF_VER=3.2.0
+ export PROTOBUFC_VER=1.2.1
+ export JSON_VER=0.12
+ export PROJSO=libproj-12.dll
fi;
+export PROTOBUF_VER=3.2.0
+export PROTOBUFC_VER=1.2.1
+export JSON_VER=0.12
+export PCRE_VER=8.33
+if [[ "${ICON_VER}" == '' ]] ; then
+fi;
+echo "ICON_VER ${ICON_VER}"
#set to something even if override is on but not set
if [[ "${ZLIB_VER}" == '' ]] ; then
fi;
-export PCRE_VER=8.33
if [[ "${LIBXML_VER}" == '' ]] ; then
export LIBXML_VER=2.7.8
fi;
#export GDAL_VER=2.4.0
+#export PROJ_VER=5.2.0
+echo "ZLIB_VER $ZLIB_VER"
+echo "PROJ_VER $PROJ_VER"
+echo "LIBXML_VER $LIBXML_VER"
export PROJECTS=/projects
export MINGPROJECTS=/projects
export PATHOLD=$PATH
if [ "$OS_BUILD" == "64" ] ; then
export MINGHOST=x86_64-w64-mingw32
else
@@ -38,7 +52,7 @@
export MINGHOST=i686-w64-mingw32
fi;
-export PATHOLD="/mingw/bin:/mingw/include:/mingw/lib:/c/Windows/system32:/c/Windows:.:/bin:/include:/usr/local/bin:/c/ming${OS_BUILD}/svn"
+echo PATH AFTER: $PATH
#export PG_VER=9.2beta2
export PGWINVER=${PG_VER}edb
export WORKSPACE=`pwd`
@@ -67,7 +81,6 @@
fi;
fi;
-export LIBXML_VER=2.7.8
#export POSTGIS_SRC=${PROJECTS}/postgis/trunk
export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
@@ -74,12 +87,13 @@
export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD}
export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
-#PATH="${MINGPROJECTS}/gettext/rel-gettext-0.18.1/bin:${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtk/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}/bin:${PATH}"
-PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
+export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig::${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig"
+export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
+CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include"
#add protobuf
export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-#export PKG_CONFIG_PATH=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig;
@@ -106,7 +120,6 @@
export PATH="${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
fi
-export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig ${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig"
if [ -n "$SFCGAL_VER" ]; then
@@ -117,34 +130,34 @@
export BOOST_VER_WU=1_53_0
export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-#note need to --enable-auto-import for LDFLAGS because wagyu fails to compile in without that.
-#See https://trac.osgeo.org/postgis/ticket/440
#CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
-#CFLAGS="-Wall -fno-omit-frame-pointer" \
+#CFLAGS="-Wall -fno-omit-frame-pointer"
-LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
+#LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
+LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
./configure \
- --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config \
+ --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config \
--with-pgconfig=${PGPATH}/bin/pg_config \
--with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/geos-config \
+ --with-projdir=${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE} \
--with-libiconv=${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE} \
--with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
--with-gui --with-gettext=no \
--with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
- --with-projdir=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE} \
--without-interrupt-tests \
--prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE}
+ #exit
else
-#CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
-./configure \
+CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
+CFLAGS="-Wall -fno-omit-frame-pointer" \
+LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib" ./configure \
@@ -151,12 +164,11 @@
fi;
make clean
#patch liblwgeom generated make to get rid of dynamic linking
#sed -i 's/LDFLAGS += -no-undefined//g' liblwgeom/Makefile
-#make uninstall
-make && make install
+make
+make install
Modified: trunk/ci/winnie/package_postgis.sh
--- trunk/ci/winnie/package_postgis.sh 2019-06-28 18:03:24 UTC (rev 17569)
+++ trunk/ci/winnie/package_postgis.sh 2019-07-01 01:27:27 UTC (rev 17570)
@@ -14,24 +14,39 @@
#export GCC_TYPE=
#if no override is set - use these values
#otherwise use the ones jenkins passes thru
+#!/bin/bash
+#!/bin/bash
+set -e
export GEOS_VER=3.8
fi;
+fi;
fi;
@@ -38,7 +53,12 @@
fi;
+#export GDAL_VER=2.4.0
Modified: trunk/ci/winnie/regress_postgis.sh
--- trunk/ci/winnie/regress_postgis.sh 2019-06-28 18:03:24 UTC (rev 17569)
+++ trunk/ci/winnie/regress_postgis.sh 2019-07-01 01:27:27 UTC (rev 17570)
@@ -5,20 +5,31 @@
fi;
+fi;
fi;
@@ -28,7 +39,9 @@
@@ -40,7 +53,7 @@
fi;
@@ -75,12 +88,13 @@
-PATH="${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
#add protobuf
-export PKG_CONFIG_PATH=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig;
@@ -107,10 +121,8 @@
fi
##hard code versions of cgal etc. for now
@@ -119,34 +131,34 @@
./configure \
+ #exit
else
-./configure \
@@ -153,6 +165,7 @@
fi;
make clean
