[postgis-tickets] r17424 - update cunit output for postgis vector
Regina Obe
lr at pcorp.us
Thu May 2 08:33:03 PDT 2019
Author: robe
Date: 2019-05-02 08:33:03 -0700 (Thu, 02 May 2019)
New Revision: 17424
trunk/doc/installation.xml
Modified: trunk/doc/installation.xml
--- trunk/doc/installation.xml 2019-05-01 21:32:41 UTC (rev 17423)
+++ trunk/doc/installation.xml 2019-05-02 15:33:03 UTC (rev 17424)
@@ -841,7 +841,8 @@
</para>
<programlisting>
- CUnit - A unit testing framework for C - Version 2.1-2
+ CUnit - A unit testing framework for C - Version 2.1-3
http://cunit.sourceforge.net/
@@ -855,6 +856,7 @@
Test: test_lwpoint_get_ordinate ...passed
Test: test_point_interpolate ...passed
Test: test_lwline_interpolate_points ...passed
+ Test: test_lwline_interpolate_point_3d ...passed
Test: test_lwline_clip ...passed
Test: test_lwpoly_clip ...passed
Test: test_lwtriangle_clip ...passed
@@ -886,7 +888,8 @@
Suite: geometry_clean
Test: test_lwgeom_make_valid ...passed
Suite: clip_by_rectangle
- Test: test_lwgeom_clip_by_rect ...passed
+ Test: test_lwgeom_clip_by_rect ...DEBUG1: lwgeom_clip_by_rect: GEOS Error: IllegalArgumentException: Invalid number of points in LinearRing found 3 - must be 0 or >= 4
+passed
Suite: force_sfs
Test: test_sfs_11 ...passed
Test: test_sfs_12 ...passed
@@ -1004,10 +1007,11 @@
Suite: measures
Test: test_mindistance2d_tolerance ...passed
Test: test_mindistance3d_tolerance ...NOTICE: One or both of the geometries is missing z-value. The unknown z-value will be regarded as "any value"
+NOTICE: One or both of the geometries is missing z-value. The unknown z-value will be regarded as "any value"
passed
Test: test_rect_tree_contains_point ...passed
Test: test_rect_tree_intersects_tree ...passed
- Test: test_lwgeom_segmentize2d ...NOTICE: ptarray.c:445 - ptarray_segmentize2d: Too many segments required (1.000000e+101)
+ Test: test_lwgeom_segmentize2d ...NOTICE: ptarray.c:448 - ptarray_segmentize2d: Too many segments required (1.000000e+101)
NOTICE: liblwgeom code interrupted
@@ -1203,11 +1207,10 @@
Run Summary: Type Total Ran Passed Failed Inactive
suites 44 44 n/a 0 0
- tests 299 299 299 0 0
- asserts 4087 4087 4087 0 n/a
+ tests 300 300 300 0 0
+ asserts 4215 4215 4215 0 n/a
+Elapsed time = 0.229 seconds
-Elapsed time = 0.196 seconds
PostgreSQL 12devel on x86_64-w64-mingw32, compiled by gcc.exe (x86_64-posix-seh-rev0, Built by MinGW-W64 project) 8.1.0, 64-bit
Postgis 3.0.0dev - r17081 - 2018-11-28 18:50:02
scripts 3.0.0dev r17081
