[postgis-tickets] r17435 - Add note to valid regarding 2d-only nature
Paul Ramsey pramsey at cleverelephant.ca
Thu May 9 09:14:36 PDT 2019
Author: pramsey
Date: 2019-05-09 09:14:36 -0700 (Thu, 09 May 2019)
New Revision: 17435
   trunk/doc/reference_validation.xml
closes #4364
Modified: trunk/doc/reference_validation.xml
--- trunk/doc/reference_validation.xml	2019-05-09 13:21:17 UTC (rev 17434)
+++ trunk/doc/reference_validation.xml	2019-05-09 16:14:36 UTC (rev 17435)
@@ -17,7 +17,7 @@
 	  <refnamediv>
 		<refname>ST_IsValid</refname>
-		<refpurpose>Tests if a geometry is well-formed.
+		<refpurpose>Tests if a geometry is well-formed in 2D.
 		</refpurpose>
 	  </refnamediv>
@@ -40,10 +40,12 @@
 	  <refsection>
 		<title>Description</title>
-		<para>Test if an ST_Geometry value is well-formed according to the OGC rules.
-		  For geometries that are invalid,
-			the PostgreSQL NOTICE will provide details of why it is not valid.  </para>
 		<para>
+                  Test if an ST_Geometry value is well-formed in 2D according to the OGC rules.
+		  For geometries that are invalid, the PostgreSQL NOTICE will provide details of why it is not valid.
+                  For geometries with 3 and 4 dimensions, the validity still only tested in 2 dimensions.
+                </para>
+		<para>
 For the version with flags,
 supported <varname>flags</varname> are documented in <xref linkend="ST_IsValidDetail" />
 This version does not print a NOTICE explaining invalidity.
