[postgis-tickets] [PostGIS] #4389: ST_SimplifyPreserveTopology doesn't always preserve topology with inner holes
trac at osgeo.org
Thu May 9 12:24:20 PDT 2019
holes
Reporter: pnorman | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.3
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by mdavis):
This is a known bug in the original JTS implementation (see
[http://locationtech.github.io/jts/javadoc/org/locationtech/jts/simplify/TopologyPreservingSimplifier.html
Javadoc] ).
As mentioned there, the workaround is to simply remove holes which lie
outside the polygon shell. But of course this needs to be implemented in
GEOS (and JTS too ideally). There should be a GEOS ticket created for
this.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4389#comment:1>
