[postgis-tickets] [PostGIS] #4397: A function to drape linestring with TIN
trac at osgeo.org
Thu May 16 14:28:59 PDT 2019
Reporter: komzpa | Owner: komzpa
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
per discussion with pramsey:
- should take a TIN and linestring, promote linestring to have Z
dimension with default of 0;
- for all covered points of linestring, set Z by interpolating on
triangle;
- for all spots where linestring hits edge of triangle, generate
intermediate points with Z from triangle.
- all values outside of TIN should be unchanged.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4397>
