[postgis-tickets] [PostGIS] #4399: Support TIN in output functions
PostGIS trac at osgeo.org
Fri May 17 08:24:03 PDT 2019
 Reporter:  komzpa       |      Owner:  komzpa
     Type:  enhancement  |     Status:  assigned
 Priority:  medium       |  Milestone:  PostGIS 3.0.0
Component:  postgis      |    Version:  trunk
 Keywords:               |
 Check and add support for TIN to be serialized into output formats. If a
 format does not have support for TIN or Triangle, it should be exposed as
 geometrycollection and polygon.
 http://www.postgis.net/docs/reference.html#Geometry_Outputs
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4399>
