[postgis-tickets] [PostGIS] #4402: raster2pgsql debug methods needed, GEOTIFF stalling for hours on addrasterconstraints
trac at osgeo.org
Fri May 24 11:35:28 PDT 2019
Reporter: osgeoap | Owner: Bborie Park
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.8
Component: raster | Version: 2.4.x
Resolution: | Keywords: addrasterconstraint, raster2pgsql
Changes (by robe):
* owner: pramsey => Bborie Park
* component: postgis => raster
Comment:
addrasterconstraints you could leave out the -C option so it doesn't add
the contraint and just add them individually.
Usually the culprit is the extent constraint because that one has to build
a big old extent check across the whole table to apply.
Are you loading my rows than usual or you were just only applying few in
the past.
Also what exact command are you using on raster2pgsql?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4402#comment:1>
