[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. b965e3a4c6ee71bc549ef72884061dfdc8ab456e
git at osgeo.org
git at osgeo.org
Fri May 24 16:01:05 PDT 2019
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
via b965e3a4c6ee71bc549ef72884061dfdc8ab456e (commit)
from 437a08ef394ffab011acf21fafb360ef9a0a449a (commit)
revisions in full, below.
commit b965e3a4c6ee71bc549ef72884061dfdc8ab456e
Author: Regina Obe <lr at pcorp.us>
Date: Fri May 24 19:01:01 2019 -0400
Missed a spot and also get rid of a config long gone
diff --git a/windows/mingw64/scripts/geos_make_install_check_branch.sh b/windows/mingw64/scripts/geos_make_install_check_branch.sh
index dfa5e98..b691967 100644
--- a/windows/mingw64/scripts/geos_make_install_check_branch.sh
+++ b/windows/mingw64/scripts/geos_make_install_check_branch.sh
@@ -51,9 +51,9 @@ if [[ "$MAKE_TYPE" == *cmake* ]] ; then
cd build${OS_BUILD}${MAKE_TYPE}
if [[ "${OS_BUILD}" == "64" ]] ; then
- cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DHAVE_LONG_LONG_INT_64=1 -DGEOS_ENABLE_INLINE=NO -DGEOS_ENABLE_TESTS=ON - ../${CMAKE_GEOS_VER}
+ cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DHAVE_LONG_LONG_INT_64=1 -DGEOS_ENABLE_INLINE=NO -DDISABLE_GEOS_INLINE=ON - ../${CMAKE_GEOS_VER}
else
- cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DGEOS_ENABLE_INLINE=NO -DGEOS_ENABLE_TESTS=ON - ../${CMAKE_GEOS_VER}
+ cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DGEOS_ENABLE_INLINE=NO -DDISABLE_GEOS_INLINE=ON - ../${CMAKE_GEOS_VER}
fi
make && make install
make check
Summary of changes:
windows/mingw64/scripts/geos_make_install_check_branch.sh | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
