[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. 1db98908992ab861e5cc55b0cf50b6e7a052bf8c
git at osgeo.org
git at osgeo.org
Sat May 25 19:40:03 PDT 2019
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
via 1db98908992ab861e5cc55b0cf50b6e7a052bf8c (commit)
from b965e3a4c6ee71bc549ef72884061dfdc8ab456e (commit)
revisions in full, below.
commit 1db98908992ab861e5cc55b0cf50b6e7a052bf8c
Author: Regina Obe <lr at pcorp.us>
Date: Sat May 25 22:39:59 2019 -0400
Updated instructions
diff --git a/debian/jenkins_setup.txt b/debian/jenkins_setup.txt
index 5e565a1..fcf0de0 100644
--- a/debian/jenkins_setup.txt
+++ b/debian/jenkins_setup.txt
@@ -3,6 +3,7 @@ On 64-bit Debian 6
su root
apt update
apt upgrade #install latest patches
+apt install gnupg2 wget
wget -q -O - http://pkg.jenkins-ci.org/debian/jenkins-ci.org.key | apt-key add -
Add to: /etc/apt/sources.list
diff --git a/debian/scripts/proj_make_install_check_branch.sh b/debian/scripts/proj_make_install_check_branch.sh
new file mode 100644
index 0000000..489270a
--- /dev/null
+++ b/debian/scripts/proj_make_install_check_branch.sh
@@ -0,0 +1,30 @@
+ #export PROJ_VER=5.2.0
+ export PROJ_VER=6.0.0
+ #export DATUM_VER=1.8
+ #export DATUM_VER=world-1.0RC1
+ export DATUM_VER=world-1.0RC1
+ export DATUM_VER=north-america-1.1RC1
+ export PATH="/mingw/bin:/mingw/include:/mingw/lib:/bin"
+ export ZLIB_VER=1.2.11
+ export ZLIB_PATH=/projects/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}
+ #wget --no-check-certificate http://zlib.net/zlib-1.2.11.tar.gz
+ export PATH="/bin:/mingw/bin:/mingw/include:${ZLIB_PATH}/bin:${ZLIB_PATH}/lib:${ZLIB_PATH}/include"
+ export PATH=${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/bin:${PATH}
+ export PKG_CONFIG_PATH=${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib
+ cd ${SOURCES}
+ #rm -rf proj-${PROJ_VER}
+ #wget http://download.osgeo.org/proj/proj-${PROJ_VER}.tar.gz
+ #wget http://download.osgeo.org/proj/proj-datumgrid-${DATUM_VER}.zip
+ #wget https://download.osgeo.org/proj/proj-datumgrid-north-america-1.1RC1.zip
+ #tar xvfz proj-${PROJ_VER}.tar.gz
+ cd proj-${PROJ_VER}
+ make clean
+ #cd nad
+ #unzip ../../proj-datumgrid-${DATUM_VER}.zip
+ #cd ..
+ ./configure --enable-shared --disable-static --prefix=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE} --build=${MINGHOST}
+ #make clean
+ make && make install
+ cd ${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}
+ strip bin/*.dll
\ No newline at end of file
Summary of changes:
debian/jenkins_setup.txt | 1 +
debian/scripts/proj_make_install_check_branch.sh | 30 ++++++++++++++++++++++++
2 files changed, 31 insertions(+)
create mode 100644 debian/scripts/proj_make_install_check_branch.sh
hooks/post-receive
