[postgis-tickets] [PostGIS] #4408: can't compile --with-wagyu under mingw64
trac at osgeo.org
Fri May 31 09:57:22 PDT 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: 2.4.x
Keywords: |
../deps/wagyu/libwagyu.la(lwgeom_wagyu.o):lwgeom_wagyu.cpp:(.rdata$_ZTISt13runtime_error[_ZTISt13runtime_error]+0x0):
undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
../deps/wagyu/libwagyu.la(lwgeom_wagyu.o):lwgeom_wagyu.cpp:(.rdata$_ZTISt9exception[_ZTISt9exception]+0x0):
undefined reference to `vtable for __cxxabiv1::__class_type_info'
../deps/wagyu/libwagyu.la(lwgeom_wagyu.o):lwgeom_wagyu.cpp:(.rdata$.refptr._ZSt7nothrow[.refptr._ZSt7nothrow]+0x0):
undefined reference to `std::nothrow'
collect2.exe: error: ld returned 1 exit status
make[1]: ***
[C:/MING64~1/projects/POSTGR~1/rel/PG12W6~2/lib/pgxs/src/MAKEFI~1/../../src/Makefile.shlib:386:
postgis-3.dll] Error 1
This is using gcc 8.1
gcc.exe (x86_64-posix-seh-rev0, Built by MinGW-W64 project) 8.1.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4408>
