[postgis-tickets] [PostGIS] #4408: can't compile --with-wagyu under mingw64
PostGIS trac at osgeo.org
Fri May 31 14:32:36 PDT 2019
  Reporter:  robe     |      Owner:  Algunenano
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 here is the error including the command prior
 gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
 statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wformat-
 security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-
 format-truncation -Wno-stringop-truncation -g -O2   -shared -static-libgcc
 -o postgis-3.dll  postgis_module.o lwgeom_accum.o lwgeom_spheroid.o
 lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_inout.o
 lwgeom_functions_basic.o lwgeom_btree.o lwgeom_box.o lwgeom_box3d.o
 lwgeom_geos.o lwgeom_sfcgal.o lwgeom_geos_prepared.o lwgeom_geos_clean.o
 lwgeom_geos_relatematch.o lwgeom_export.o lwgeom_in_gml.o lwgeom_in_kml.o
 lwgeom_in_geohash.o lwgeom_in_geojson.o lwgeom_in_encoded_polyline.o
 lwgeom_triggers.o lwgeom_dump.o lwgeom_dumppoints.o lwgeom_functions_lrs.o
 lwgeom_functions_temporal.o lwgeom_rectree.o long_xact.o lwgeom_sqlmm.o
 lwgeom_rtree.o lwgeom_transform.o lwgeom_window.o gserialized_typmod.o
 gserialized_gist_2d.o gserialized_gist_nd.o gserialized_supportfn.o
 gserialized_spgist_2d.o gserialized_spgist_3d.o gserialized_spgist_nd.o
 brin_2d.o brin_nd.o brin_common.o gserialized_estimate.o geography_inout.o
 geography_btree.o geography_centroid.o geography_measurement.o
 geography_measurement_trees.o geometry_inout.o postgis_libprotobuf.o
 vector_tile.pb-c.o geobuf.pb-c.o mvt.o lwgeom_out_mvt.o geobuf.o
 lwgeom_out_geobuf.o lwgeom_out_geojson.o postgis_legacy.o
 -LC:/MING64~1/projects/POSTGR~1/rel/PG12W6~2/lib  -L/projects/zlib/rel-
 zlib-1.2.11w64gcc81/lib -L/projects/libxml/rel-libxml2-2.7.8w64gcc81/lib
 -Wl,--allow-multiple-definition -Wl,--disable-auto-import
 -L/projects/libxml/rel-libxml2-2.7.8w64gcc81/lib  -Wl,--as-needed
 ../deps/wagyu/libwagyu.la -lstdc++ ../libpgcommon/libpgcommon.a
 ../liblwgeom/.libs/liblwgeom.a
 -LC:/ming64gcc81/projects/geos/rel-3.8w64gcc81/lib -lgeos_c
 -L/projects/proj/rel-6.0.0w64gcc81/lib -lproj
 -L/projects/protobuf/rel-3.2.0w64gcc81/lib -lprotobuf-c -L/projects/libxml
 /rel-libxml2-2.7.8w64gcc81/lib -lxml2 -lws2_32 -L/projects/CGAL/rel-
 sfcgal-1.3.2w64gcc81/lib -lSFCGAL -Wl,--exclude-libs,ALL  -L/projects/CGAL
 /rel-sfcgal-1.3.2w64gcc81/lib -lSFCGAL
 -LC:/MING64~1/projects/POSTGR~1/rel/PG12W6~2/lib -lpostgres -lpgcommon
 -lpgport -lxml2 -lz -lws2_32 -lm  -lws2_32 -Wl,--export-all-symbols -Wl
 ,--out-implib=libpostgis-3.a
 ../deps/wagyu/libwagyu.la(lwgeom_wagyu.o):lwgeom_wagyu.cpp:(.rdata$_ZTISt13runtime_error[_ZTISt13runtime_error]+0x0):
 undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
 ../deps/wagyu/libwagyu.la(lwgeom_wagyu.o):lwgeom_wagyu.cpp:(.rdata$_ZTISt9exception[_ZTISt9exception]+0x0):
 undefined reference to `vtable for __cxxabiv1::__class_type_info'
 ../deps/wagyu/libwagyu.la(lwgeom_wagyu.o):lwgeom_wagyu.cpp:(.rdata$.refptr._ZSt7nothrow[.refptr._ZSt7nothrow]+0x0):
 undefined reference to `std::nothrow'
 collect2.exe: error: ld returned 1 exit status
 make[1]: ***
 [C:/MING64~1/projects/POSTGR~1/rel/PG12W6~2/lib/pgxs/src/MAKEFI~1/../../src/Makefile.shlib:386:
 postgis-3.dll] Error 1
 make[1]: Leaving directory '/projects/postgis/branches/3.0/postgis'
 make: *** [GNUmakefile:20: all] Error 1
 in config.log - no warning just a
 configure:18519: result: none required
 configure:18595: result: WAGYU: Wagyu usage requested
 configure:18726: checking for C++ compiler version
 configure:18735: gcc --version >&5
 gcc.exe (x86_64-posix-seh-rev0, Built by MinGW-W64 project) 8.1.0
 and configure out shows this
 -------------- Compiler Info -------------
   C compiler:           x86_64-w64-mingw32-gcc -std=gnu99 -g -O2 -fno-
 math-errno -fno-signed-zeros
   C++ compiler (Wagyu): gcc -std=c++11 -x c++
   CPPFLAGS:
 -IC:/ming64gcc81/projects/geos/rel-3.8w64gcc81/include
 -I/projects/proj/rel-6.0.0w64gcc81/include
 -I/projects/protobuf/rel-3.2.0w64gcc81/include -I/projects/libxml/rel-
 libxml2-2.7.8w64gcc81/include/libxml2 -I/projects/CGAL/rel-
 sfcgal-1.3.2w64gcc81/include
 -I/projects/json-c/rel-0.12w64gcc81/include/json-c
   SQL preprocessor:     /mingw/bin/cpp -traditional-cpp -w -P
  -------------- Additional Info -------------
   Interrupt Tests:   DISABLED use: --with-interrupt-tests to enable
  -------------- Dependencies --------------
   GEOS config:          /projects/geos/rel-3.8w64gcc81/bin/geos-config
   GEOS version:         3.8.0
   GDAL config:          /projects/gdal/rel-2.3.1w64gcc81/bin/gdal-config
   GDAL version:         2.3.1
   SFCGAL config:        /projects/CGAL/rel-sfcgal-1.3.2w64gcc81/bin
 /sfcgal-config
   SFCGAL version:       1.3.2
   PostgreSQL config:
 /projects/postgresql/rel/pg12w64gcc81/bin/pg_config
   PostgreSQL version:   PostgreSQL 12beta1
   PROJ4 version:        60
   Libxml2 config:       /projects/libxml/rel-
 libxml2-2.7.8w64gcc81/bin/xml2-config
   Libxml2 version:      2.7.8
   JSON-C support:       no
   protobuf-c support:   yes
   PCRE support:         no
   Perl:                 /bin/perl
   Wagyu:                yes
  --------------- Extensions ---------------
   PostGIS Raster:                     enabled
 I'm going to go ahead and turn on winnie's wagyu -- she's still building
 with an older compiler but sometimes that one for whatever reason doesn't
 run into the same issues my newer one does.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4408#comment:2>
