[postgis-tickets] [PostGIS] #4409: Configure debbie and bessies to build with mvt support
PostGIS trac at osgeo.org
Fri May 31 18:02:14 PDT 2019
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  PostGIS 2.5.3
 Component:  buildbots  |    Version:  2.4.x
Resolution:             |   Keywords:
Comment (by robe):
 Move info when I do the below on debbie
 protoc --version
 outputs: libprotoc 3.6.1
  pkg-config --libs 'libprotobuf-c >= 1.0.0'
 gives me error
 No package 'libprotobuf-c' found
 Running the same command on bessie gives
 -L/usr/local/lib -lprotobuf-c
 So there does seem to be something wrong with the pkg-config bit
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4409#comment:3>
