[postgis-tickets] r17452 - take off --with-wagyu on buildbots now that's the default no longer necessary
Regina Obe
lr at pcorp.us
Fri May 31 07:10:07 PDT 2019
Author: robe
Date: 2019-05-31 19:10:06 -0700 (Fri, 31 May 2019)
New Revision: 17452
trunk/ci/bessie/postgis_regress.sh
trunk/ci/bessie32/postgis_regress.sh
trunk/ci/debbie/postgis_regress.sh
trunk/ci/winnie/build_postgis.sh
trunk/ci/winnie/regress_postgis.sh
Revise winnie's builds to use pkgconfig where available instead of the --with-<something>=path commands
Modified: trunk/ci/bessie/postgis_regress.sh
--- trunk/ci/bessie/postgis_regress.sh 2019-06-01 01:29:14 UTC (rev 17451)
+++ trunk/ci/bessie/postgis_regress.sh 2019-06-01 02:10:06 UTC (rev 17452)
@@ -1,7 +1,7 @@
#BRANCH is passed in via jenkins which is set via svn hook
export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
sh autogen.sh
-./configure --with-projdir=/usr/local --with-libiconv=/usr/local --with-wagyu --without-interrupt-tests
+./configure --with-projdir=/usr/local --with-libiconv=/usr/local --without-interrupt-tests
make clean
make
export PGUSER=postgres
Modified: trunk/ci/bessie32/postgis_regress.sh
--- trunk/ci/bessie32/postgis_regress.sh 2019-06-01 01:29:14 UTC (rev 17451)
+++ trunk/ci/bessie32/postgis_regress.sh 2019-06-01 02:10:06 UTC (rev 17452)
@@ -1,6 +1,6 @@
sh autogen.sh
make clean
make
Modified: trunk/ci/debbie/postgis_regress.sh
--- trunk/ci/debbie/postgis_regress.sh 2019-06-01 01:29:14 UTC (rev 17451)
+++ trunk/ci/debbie/postgis_regress.sh 2019-06-01 02:10:06 UTC (rev 17452)
@@ -65,7 +65,6 @@
--with-pgconfig=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}/bin/pg_config \
--with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config \
--with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config \
- --with-wagyu \
--without-interrupt-tests \
--prefix=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}
make clean
Modified: trunk/ci/winnie/build_postgis.sh
--- trunk/ci/winnie/build_postgis.sh 2019-06-01 01:29:14 UTC (rev 17451)
+++ trunk/ci/winnie/build_postgis.sh 2019-06-01 02:10:06 UTC (rev 17452)
@@ -103,6 +103,8 @@
export PATH="${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
fi
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig"
if [ -n "$SFCGAL_VER" ]; then
BOOST_VER=1.53.0
#BOOST_VER_WU=1_49_0
@@ -115,15 +117,10 @@
--host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config \
--with-pgconfig=${PGPATH}/bin/pg_config \
--with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/geos-config \
- --with-projdir=${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE} \
- --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/gdal-config \
- --with-jsondir=${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE} \
--with-libiconv=${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE} \
--with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
--with-gui --with-gettext=no \
- --with-protobufdir=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE} \
--with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
- --with-pcredir=${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE} \
--prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE}
else
@@ -133,11 +130,7 @@
Modified: trunk/ci/winnie/regress_postgis.sh
--- trunk/ci/winnie/regress_postgis.sh 2019-06-01 01:29:14 UTC (rev 17451)
+++ trunk/ci/winnie/regress_postgis.sh 2019-06-01 02:10:06 UTC (rev 17452)
@@ -97,6 +97,9 @@
fi
##hard code versions of cgal etc. for now
export CGAL_VER=4.11
@@ -113,16 +116,10 @@
--with-libiconv=${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE} \
- --with-wagyu \
else
@@ -132,12 +129,7 @@
- --with-wagyu \
- --with-jsondir=${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE} \
