[postgis-tickets] r17844 - Fix scripts-based (not extension) upgrade from 2.4
Paul Ramsey
pramsey at cleverelephant.ca
Tue Oct 1 10:28:59 PDT 2019
Author: pramsey
Date: 2019-10-01 10:28:59 -0700 (Tue, 01 Oct 2019)
New Revision: 17844
trunk/postgis/postgis_before_upgrade.sql
Closes #4516
Modified: trunk/postgis/postgis_before_upgrade.sql
--- trunk/postgis/postgis_before_upgrade.sql 2019-10-01 17:11:28 UTC (rev 17843)
+++ trunk/postgis/postgis_before_upgrade.sql 2019-10-01 17:28:59 UTC (rev 17844)
@@ -34,7 +34,6 @@
-- LOWER(p.proname) = LOWER('ST_AsGeoJson')
-- ORDER BY 1, 2, 3, 4;
CREATE OR REPLACE FUNCTION _postgis_drop_function_if_needed(
- function_schema text,
function_name text,
function_arguments text) RETURNS void AS $$
DECLARE
@@ -44,6 +43,7 @@
FOR frec IN
SELECT p.oid as oid,
n.nspname as schema,
+ n.oid as schema_oid,
p.proname as name,
pg_catalog.pg_get_function_arguments(p.oid) as arguments,
pg_catalog.pg_get_function_identity_arguments(p.oid) as identity_arguments
@@ -50,7 +50,12 @@
FROM pg_catalog.pg_proc p
LEFT JOIN pg_catalog.pg_namespace n ON n.oid = p.pronamespace
WHERE
- LOWER(n.nspname) = LOWER(function_schema) AND
+ n.oid = (
+ SELECT n.oid
+ FROM pg_proc p
+ JOIN pg_namespace n ON p.pronamespace = n.oid
+ WHERE proname = 'postgis_full_version'
+ ) AND
LOWER(p.proname) = LOWER(function_name) AND
LOWER(pg_catalog.pg_get_function_arguments(p.oid)) ~ LOWER(function_arguments) AND
pg_catalog.pg_function_is_visible(p.oid)
@@ -65,7 +70,7 @@
EXECUTE sql_drop;
EXCEPTION
WHEN OTHERS THEN
- RAISE EXCEPTION 'Could not drop function %.%. You might need to drop dependant objects. Postgres error: %', function_schema, function_name, SQLERRM;
+ RAISE EXCEPTION 'Could not drop function %. You might need to drop dependant objects. Postgres error: %', function_name, SQLERRM;
END;
END LOOP;
END;
@@ -76,7 +81,6 @@
-- (catalog_name character varying, schema_name character varying, table_name character varying, column_name character varying, new_srid integer, new_type character varying, new_dim integer, use_typmod boolean)
SELECT _postgis_drop_function_if_needed
- '@extschema@',
'AddGeometryColumn',
'catalog_name character varying, schema_name character varying, table_name character varying, column_name character varying, new_srid integer, new_type character varying, new_dim integer, use_typmod boolean'
@@ -85,7 +89,6 @@
-- (geom geometry, prec integer, options integer)
- '@extschema@',
'ST_AsX3D',
'geom geometry, prec integer, options integer'
@@ -96,7 +99,6 @@
-- Dropping it conditionally since the same signature still exists.
- '@extschema@',
'UpdateGeometrySRID',
'catalogn_name character varying, schema_name character varying, table_name character varying, column_name character varying, new_srid integer'
@@ -138,20 +140,26 @@
-- FUNCTION ST_AsLatLonText went from multiple signatures to a single one with defaults for 2.2.0
DROP FUNCTION IF EXISTS ST_AsLatLonText(geometry); -- Does not conflict
- '@extschema@',
'ST_AsLatLonText',
'geometry, text'
+-- FUNCTION ST_LineCrossingDirection changed argument names in 3.0
+-- Was (geom1 geometry, geom2 geometry) and now (line1 geometry, line2 geometry)
+SELECT _postgis_drop_function_if_needed
+ 'ST_LineCrossingDirection',
+ 'geom1 geometry, geom2 geometry'
-- FUNCTION _st_linecrossingdirection changed argument names in 3.0
- '@extschema@',
- '_st_linecrossingdirection',
+ '_ST_LineCrossingDirection',
@@ -159,26 +167,14 @@
-- (pretty_print => pretty_bool) in 3.0alpha4
- '@extschema@',
'ST_AsGeoJson',
$args$r record, geom_column text DEFAULT ''::text, maxdecimaldigits integer DEFAULT 15, pretty_print boolean DEFAULT false$args$
--- FUNCTION ST_LineCrossingDirection changed argument names in 3.0
--- Was (geom1 geometry, geom2 geometry) and now (line1 geometry, line2 geometry)
-SELECT _postgis_drop_function_if_needed
- '@extschema@',
- 'ST_LineCrossingDirection',
- 'geom1 geometry, geom2 geometry'
-- FUNCTION _st_orderingequals changed argument names in 3.0
-- Was (GeometryA geometry, GeometryB geometry) and now (geom1 geometry, geom2 geometry)
- '@extschema@',
'_st_orderingequals',
'GeometryA geometry, GeometryB geometry'
@@ -187,7 +183,6 @@
- '@extschema@',
'st_orderingequals',
@@ -250,4 +245,5 @@
-- DROP auxiliar function (created above)
-DROP FUNCTION _postgis_drop_function_if_needed(text, text, text);
+DROP FUNCTION _postgis_drop_function_if_needed(text, text);
