[postgis-tickets] r17846 - getSRIDbySRS: Fix crash
Raul
raul at rmr.ninja
Wed Oct 2 06:45:21 PDT 2019
Author: algunenano
Date: 2019-10-02 06:45:21 -0700 (Wed, 02 Oct 2019)
New Revision: 17846
trunk/NEWS
trunk/postgis/lwgeom_export.c
- Prevents stack overflow when the srs is long (query + srs > 256 chars).
- Prevents sql injection.
References #4519
Closes https://github.com/postgis/postgis/pull/487
Modified: trunk/NEWS
--- trunk/NEWS 2019-10-01 17:29:34 UTC (rev 17845)
+++ trunk/NEWS 2019-10-02 13:45:21 UTC (rev 17846)
@@ -1,8 +1,16 @@
PostGIS 3.0.0beta2
2019/10/xx
+For full changes and enhancements, refer to PostGIS 3.0.0.
+This version requires PostgreSQL 9.5+-12 and GEOS >= 3.6+
+Additional features enabled if you are running Proj6+ and PostgreSQL 12
+Additional performance enhancements if running GEOS 3.8+
+* Major highlights *
+ - #4519, Fix getSRIDbySRS crash (Raúl Marín)
PostGIS 3.0.0beta1
2019/09/28
Modified: trunk/postgis/lwgeom_export.c
--- trunk/postgis/lwgeom_export.c 2019-10-01 17:29:34 UTC (rev 17845)
+++ trunk/postgis/lwgeom_export.c 2019-10-02 13:45:21 UTC (rev 17846)
@@ -29,7 +29,9 @@
#include "float.h" /* for DBL_DIG */
#include "postgres.h"
+#include "catalog/pg_type.h" /* for CSTRINGOID */
#include "executor/spi.h"
#include "utils/builtins.h"
@@ -125,25 +127,25 @@
int getSRIDbySRS(const char* srs)
- char query[256];
+ char *query =
+ "SELECT srid "
+ "FROM spatial_ref_sys, "
+ "regexp_matches($1::text, E'([a-z]+):([0-9]+)', 'gi') AS re "
+ "WHERE re[1] ILIKE auth_name AND int4(re[2]) = auth_srid";
+ Oid argtypes[] = {CSTRINGOID};
+ Datum values[] = {CStringGetDatum(srs)};
int32_t srid, err;
if (!srs) return 0;
- if (SPI_OK_CONNECT != SPI_connect ())
+ if (SPI_OK_CONNECT != SPI_connect())
elog(NOTICE, "getSRIDbySRS: could not connect to SPI manager");
- SPI_finish();
return 0;
- sprintf(query,
- "SELECT srid "
- "FROM spatial_ref_sys, "
- "regexp_matches('%s', E'([a-z]+):([0-9]+)', 'gi') AS re "
- "WHERE re[1] ILIKE auth_name AND int4(re[2]) = auth_srid", srs);
- err = SPI_exec(query, 1);
- if ( err < 0 )
+ err = SPI_execute_with_args(query, 1, argtypes, values, NULL, true, 1);
+ if (err < 0)
elog(NOTICE, "getSRIDbySRS: error executing query %d", err);
SPI_finish();
@@ -153,14 +155,14 @@
/* no entry in spatial_ref_sys */
if (SPI_processed <= 0)
- sprintf(query,
- "SELECT srid "
- "regexp_matches('%s', E'urn:ogc:def:crs:([a-z]+):.*:([0-9]+)', 'gi') AS re "
+ query =
+ "SELECT srid "
+ "regexp_matches($1::text, E'urn:ogc:def:crs:([a-z]+):.*:([0-9]+)', 'gi') AS re "
- if ( err < 0 )
+ if (err < 0)
SPI_finish();
@@ -167,7 +169,8 @@
return 0;
- if (SPI_processed <= 0) {
+ if (SPI_processed <= 0)
SPI_finish();
return 0;
@@ -174,7 +177,6 @@
srid = atoi(SPI_getvalue(SPI_tuptable->vals[0], SPI_tuptable->tupdesc, 1));
SPI_finish();
return srid;
