[postgis-tickets] [PostGIS] #4516: Upgrade from 2.4 to 3.0
PostGIS trac at osgeo.org
Wed Oct 2 07:13:16 PDT 2019
  Reporter:  robe                   |      Owner:  pramsey
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  2.5.x
Resolution:                         |   Keywords:
Changes (by Algunenano):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 This has broken travis 2.4 branch: https://travis-
 ci.org/postgis/postgis/builds/592139748
 Running tests
  check_gdal .. ok
  load_outdb ... ok
  check_raster_columns .. failed (diff expected obtained:
 /tmp/pgis_reg/test_3_diff)
  check_raster_overviews .. failed (diff expected obtained:
 /tmp/pgis_reg/test_4_diff)
  rt_io .. ok
  rt_bytea .. ok
  box3d .. ok
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4516#comment:4>
