[postgis-tickets] [PostGIS] #4521: ERROR: cannot change name of input parameter "pretty_print"
trac at osgeo.org
Fri Oct 4 13:32:00 PDT 2019
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
Cannot upgrade, from 3.0.0alpha3dev:
strk=# select postgis_full_version();
-[ RECORD 1
postgis_full_version | POSTGIS="3.0.0alpha5dev r17751" [EXTENSION]
PGSQL="96" GEOS="3.8.0dev-CAPI-1.12.0 " SFCGAL="1.3.6" PROJ="Rel. 4.9.3,
15 August 2016" GDAL="GDAL 2.3.0dev, released 2017/99/99" LIBXML="2.9.4"
LIBJSON="0.12.1" LIBPROTOBUF="1.2.1" WAGYU="0.4.3 (Internal)" (core procs
from "3.0.0alpha3dev r17535" need upgrade) TOPOLOGY (topology procs from
"3.0.0alpha5dev r17729" need upgrade) [UNPACKAGED!] RASTER (raster procs
from "3.0.0alpha3dev r17535" need upgrade) (sfcgal procs from
strk=# select postgis_extensions_upgrade();
HINT: Use DROP FUNCTION st_asgeojson(record,text,integer,boolean) first.
CONTEXT: SQL statement "ALTER EXTENSION postgis UPDATE TO
"3.0.0alpha5dev";"
PL/pgSQL function postgis_extensions_upgrade() line 59 at EXECUTE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4521>
