[postgis-tickets] [PostGIS] #4522: 32bit failures regress on cluster
trac at osgeo.org
Sat Oct 5 14:36:52 PDT 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
Getting this error on bessie32 and berrie
bessie32 is a FreeBSD 12 32-bit and berrie is a 32-bit Rasberry Pi
bessie32 shows this I assume it's the same as berrie
14:20:04 cluster .. failed (diff expected obtained:
/home/jenkins/tmp/pgis_reg_a4e6e57c31689abd67b702e2bb31dd7580021ca3/test_37_diff)
14:20:04
14:20:04 --- cluster_expected 2019-10-05 14:08:48.795172000 +0000
14:20:04 +++
/home/jenkins/tmp/pgis_reg_a4e6e57c31689abd67b702e2bb31dd7580021ca3/test_37_out
2019-10-05 14:19:19.470453000 +0000
14:20:04 @@ -4,8 +4,7 @@
14:20:04 t2|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
4),LINESTRING(0 0,-1 -1),POLYGON((0 0,4 0,4 4,0 4,0 0)))
14:20:04 t2|GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
14:20:04 t2|GEOMETRYCOLLECTION(POLYGON EMPTY)
14:20:04 -t3|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
14:20:04 -t3|GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
14:20:04 +t3|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
4),LINESTRING(0 0,-1 -1),LINESTRING(6 6,7 7),POLYGON((0 0,4 0,4 4,0 4,0
0)))
14:20:04 t3|GEOMETRYCOLLECTION(POLYGON EMPTY)
14:20:04 t4|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
0)))
14:20:04 t4|GEOMETRYCOLLECTION(POLYGON EMPTY)
14:20:04
berrie
14:23:08 cluster .. failed (diff expected obtained:
/tmp/pgis_reg/test_37_diff)
14:23:08
14:23:08 --- cluster_expected 2019-10-05 11:09:27.199256309 -0700
14:23:08 +++ /tmp/pgis_reg/test_37_out 2019-10-05 11:23:08.757856166
-0700
14:23:08 @@ -4,8 +4,7 @@
14:23:08 t2|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
14:23:08 t2|GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
14:23:08 t2|GEOMETRYCOLLECTION(POLYGON EMPTY)
14:23:08 -t3|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
14:23:08 -t3|GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
14:23:08 +t3|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
0)))
14:23:08 t3|GEOMETRYCOLLECTION(POLYGON EMPTY)
14:23:08 t4|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
0)))
14:23:08 t4|GEOMETRYCOLLECTION(POLYGON EMPTY)
14:23:08
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4522>
