[postgis-tickets] [PostGIS] #4523: Upgrade 2.1.9 to 3.0.0rc1 - can not drop function st_union(geometry) because other objects depend on it
trac at osgeo.org
Sun Oct 6 08:39:21 PDT 2019
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: trunk
Keywords: |
I'm not sure this test is fair -- dronie is showing this error going from
2.1.9 to 3.0.0rc1
Died at ../run_test.pl line 1588.
failed (Error encountered altering EXTENSION POSTGIS:
/tmp/pgis_reg/regress_log)
CREATE EXTENSION
WARNING: unpackaging raster
WARNING: PostGIS Raster functionality has been unpackaged
HINT: type `SELECT postgis_extensions_upgrade(); to finish the upgrade.
After upgrading, if you want to drop raster, run: DROP EXTENSION
postgis_raster;
ERROR: cannot drop function st_union(geometry) because other objects
depend on it
DETAIL: view upgrade_view_test depends on function st_union(geometry)
HINT: Use DROP ... CASCADE to drop the dependent objects too.
CONTEXT: SQL statement "DROP AGGREGATE IF EXISTS ST_Union (geometry)"
PL/pgSQL function inline_code_block line 15 at EXECUTE
make[1]: *** [check] Error 1
make[1]: Leaving directory `/drone/src/regress/core'
make: *** [check-regress] Error 2
make: Leaving directory `/drone/src/regress'
FAIL: upgrade 2.1.9--3.0.0rc1
Can we not test 2.1.9 as that's long deprecated already and besides we
know that ST_Union changed. It's changed I think 3 times since 2.1.9 so
this is an expected failure
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4523>
