[postgis-tickets] [PostGIS] #4515: 00-regress-install doesn't get created legacy regress fails
trac at osgeo.org
Sun Oct 6 22:06:17 PDT 2019
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Comment (by strk):
The $version ne $libver conditional is to find script-based install
of non-current version, which is needed when running with
{{{ --upgrade-path "unpackagedX.Y--Z.Z" }}}
The code tries to guess where non-extension scripts for version X.Y
are found on the system.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4515#comment:9>
