[postgis-tickets] [PostGIS] #4528: --with-jsondir is broken in 3.0.0
trac at osgeo.org
Mon Oct 7 05:49:39 PDT 2019
Reporter: jabakobob | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version:
Resolution: fixed | Keywords:
Comment (by jabakobob):
What about the `HAVE_LIBJSON_C` flag? As far as I understand it's not
needed any more.
I would suggest the following patch below to remove it. Am I missing
something?
diff --git a/configure.ac b/configure.ac
index 9af7282e4..78ac17ec3 100644
--- a/configure.ac
+++ b/configure.ac
@@ -910,7 +910,6 @@ dnl
CHECK_JSON=yes
HAVE_JSON=no
-HAVE_JSON_C=no
AC_ARG_WITH([json],
[AS_HELP_STRING([--without-json], [build without json-c
support])],
@@ -935,7 +934,7 @@ if test "$CHECK_JSON" != "no"; then
AC_CHECK_FILE("$JSONDIR/include/json-c/json.h",
JSON_CPPFLAGS="-I$JSONDIR/include/json-c"
- AC_CHECK_LIB([json-c],
[json_object_get], [HAVE_JSON_C=yes; JSON_LDFLAGS="${JSON_LDFLAGS}
-ljson-c"])
+ AC_CHECK_LIB([json-c],
[json_object_get], [HAVE_JSON=yes; JSON_LDFLAGS="${JSON_LDFLAGS}
-ljson-c"])
AC_CHECK_FILE("$JSONDIR/include/json/json.h",
@@ -949,7 +948,7 @@ if test "$CHECK_JSON" != "no"; then
fi
elif test ! -z "$PKG_CONFIG"; then
PKG_CHECK_MODULES([JSONC], [json-c], [
- HAVE_JSON_C=yes
+ HAVE_JSON=yes
JSON_CPPFLAGS="$JSONC_CFLAGS"
JSON_LDFLAGS="$JSONC_LIBS"
@@ -958,16 +957,10 @@ if test "$CHECK_JSON" != "no"; then
if test "$HAVE_JSON" = "yes"; then
AC_DEFINE([HAVE_LIBJSON], 1, [Define to 1 if libjson is
present])
fi
- if test "$HAVE_JSON_C" = "yes"; then
- AC_DEFINE([HAVE_LIBJSON], 1, [Define to 1 if libjson is
present])
- AC_DEFINE([HAVE_LIBJSON_C], 1, [Define to 1 if libjson
resides in a json-c subdir])
- HAVE_JSON=yes
- fi
AC_SUBST([JSON_CPPFLAGS])
AC_SUBST([JSON_LDFLAGS])
AC_SUBST([HAVE_JSON])
- AC_SUBST([HAVE_LIBJSON_C])
fi
diff --git a/liblwgeom/lwin_geojson.c b/liblwgeom/lwin_geojson.c
index 30a5564e9..415e01134 100644
--- a/liblwgeom/lwin_geojson.c
+++ b/liblwgeom/lwin_geojson.c
@@ -28,7 +28,7 @@
#include "lwgeom_log.h"
#include "../postgis_config.h"
-#if defined(HAVE_LIBJSON) || defined(HAVE_LIBJSON_C) /* --{ */
+#if defined(HAVE_LIBJSON) /* --{ */
#define JSON_C_VERSION_013 (13 << 8)
@@ -403,7 +403,7 @@ parse_geojson(json_object *geojson, int *hasz)
return NULL; /* Never reach */
-#endif /* HAVE_LIBJSON or HAVE_LIBJSON_C --} */
+#endif /* HAVE_LIBJSON --} */
LWGEOM *
lwgeom_from_geojson(const char *geojson, char **srs)
diff --git a/postgis/lwgeom_in_geojson.c b/postgis/lwgeom_in_geojson.c
index 9d8bd7750..08b52a7e2 100644
--- a/postgis/lwgeom_in_geojson.c
+++ b/postgis/lwgeom_in_geojson.c
@@ -32,7 +32,7 @@
#include "liblwgeom.h"
#include "lwgeom_export.h"
#include <json.h>
diff --git a/postgis_config.h.in b/postgis_config.h.in
index 57afbecc0..abb6f3f02 100644
--- a/postgis_config.h.in
+++ b/postgis_config.h.in
@@ -53,9 +53,6 @@
/* Define to 1 if libjson is present */
#undef HAVE_LIBJSON
-/* Define to 1 if libjson resides in json-c subdir */
-#undef HAVE_LIBJSON_C
/* Define to 1 if you have the `pq' library (-lpq). */
#undef HAVE_LIBPQ
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4528#comment:6>
