[postgis-tickets] [PostGIS] #4517: ST_EndPoint documentation has incorrect synopsis
PostGIS trac at osgeo.org
Mon Oct 7 11:11:57 PDT 2019
  Reporter:  samuelspurling  |      Owner:  robe
      Type:  defect          |     Status:  closed
  Priority:  low             |  Milestone:  PostGIS 2.5.4
 Component:  documentation   |    Version:  2.5.x
Resolution:  fixed           |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17880" 17880]:
 #!CommitTicketReference repository="" revision="17880"
 ST_EndPoint returns a geometry, not a boolean
 Closes #4517 for PostGIS 2.5.4 (note 3.0.0 seems to be correct)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4517#comment:1>
