[postgis-tickets] [PostGIS] #4523: Upgrade 2.1.9 to 3.0.0rc1 - can not drop function st_union(geometry) because other objects depend on it
trac at osgeo.org
Mon Oct 7 13:15:08 PDT 2019
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Comment (by Algunenano):
Isn't this hitting the change done in 2.5 (internal type) and not the one
just reverted?
OTOH, I'd be ok with dropping this test. Things work as they should with
PG12.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4523#comment:5>
