[postgis-tickets] [PostGIS] #4386: [upgrade] ERROR: cannot drop function st_union(geometry) because other objects depend on it
trac at osgeo.org
Mon Oct 7 15:56:47 PDT 2019
Reporter: strk | Owner: komzpa
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Comment (by pramsey):
Yeah, this is #4523. It's not my fix here, it's the upgrade test PR from
strk that I added along the way. It tests that ST_Union views are durable
across upgrades, which I'm pretty sure they never were, because we always
did drop/create on them. We only get away from that in Pg 12 which can do
a create-or-replace. I'm commenting out strk's test.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4386#comment:12>
