[postgis-tickets] [PostGIS] #4523: Upgrade 2.1.9 to 3.0.0rc1 - can not drop function st_union(geometry) because other objects depend on it
PostGIS trac at osgeo.org
Mon Oct 7 20:37:28 PDT 2019
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Yah I think its a given if you upgrade prior to 12 and you used aggs in
 your functions, your best bet is to move to 12.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4523#comment:7>
