[postgis-tickets] r17889 - Allow running core tests from any directory
Sandro Santilli
strk at kbt.io
Tue Oct 8 03:59:05 PDT 2019
Author: strk
Date: 2019-10-08 03:59:05 -0700 (Tue, 08 Oct 2019)
New Revision: 17889
trunk/regress/core/regress.sql
trunk/regress/core/regress_brin_index.sql
trunk/regress/core/regress_brin_index_3d.sql
trunk/regress/core/regress_brin_index_geography.sql
trunk/regress/core/regress_index.sql
trunk/regress/core/regress_index_nulls.sql
trunk/regress/core/subdivide.sql
Using the :regdir variable
Modified: trunk/regress/core/regress.sql
--- trunk/regress/core/regress.sql 2019-10-08 09:43:14 UTC (rev 17888)
+++ trunk/regress/core/regress.sql 2019-10-08 10:59:05 UTC (rev 17889)
@@ -146,7 +146,7 @@
-- create a table with data that will be TOASTed (even after compression)
create table TEST(a GEOMETRY, b GEOMETRY);
-\i regress_biginsert.sql
+\i :regdir/core/regress_biginsert.sql
---test basic ops on this
Modified: trunk/regress/core/regress_brin_index.sql
--- trunk/regress/core/regress_brin_index.sql 2019-10-08 09:43:14 UTC (rev 17888)
+++ trunk/regress/core/regress_brin_index.sql 2019-10-08 10:59:05 UTC (rev 17889)
@@ -1,5 +1,5 @@
--- build a larger database
-\i regress_lots_of_points.sql
+\i :regdir/core/regress_lots_of_points.sql
--- Test the various BRIN opclass with dataset containing 2D geometries
Modified: trunk/regress/core/regress_brin_index_3d.sql
--- trunk/regress/core/regress_brin_index_3d.sql 2019-10-08 09:43:14 UTC (rev 17888)
+++ trunk/regress/core/regress_brin_index_3d.sql 2019-10-08 10:59:05 UTC (rev 17889)
@@ -1,5 +1,5 @@
-\i regress_lots_of_3dpoints.sql
+\i :regdir/core/regress_lots_of_3dpoints.sql
--- Test the various BRIN opclass with dataset containing 3D geometries, or
-- geometries of different number of dimensions
Modified: trunk/regress/core/regress_brin_index_geography.sql
--- trunk/regress/core/regress_brin_index_geography.sql 2019-10-08 09:43:14 UTC (rev 17888)
+++ trunk/regress/core/regress_brin_index_geography.sql 2019-10-08 10:59:05 UTC (rev 17889)
@@ -1,5 +1,5 @@
-\i regress_lots_of_geographies.sql
+\i :regdir/core/regress_lots_of_geographies.sql
--- test some of the searching capabilities
Modified: trunk/regress/core/regress_index.sql
--- trunk/regress/core/regress_index.sql 2019-10-08 09:43:14 UTC (rev 17888)
+++ trunk/regress/core/regress_index.sql 2019-10-08 10:59:05 UTC (rev 17889)
@@ -1,5 +1,5 @@
Modified: trunk/regress/core/regress_index_nulls.sql
--- trunk/regress/core/regress_index_nulls.sql 2019-10-08 09:43:14 UTC (rev 17888)
+++ trunk/regress/core/regress_index_nulls.sql 2019-10-08 10:59:05 UTC (rev 17889)
@@ -1,4 +1,4 @@
-\i regress_lots_of_nulls.sql
+\i :regdir/core/regress_lots_of_nulls.sql
SET client_min_messages TO NOTICE;
CREATE INDEX "test_geom_idx" ON "test" using gist (the_geom);
Modified: trunk/regress/core/subdivide.sql
--- trunk/regress/core/subdivide.sql 2019-10-08 09:43:14 UTC (rev 17888)
+++ trunk/regress/core/subdivide.sql 2019-10-08 10:59:05 UTC (rev 17889)
@@ -42,7 +42,7 @@
from inverted_geom
) z;
-\i regress_big_polygon.sql
+\i :regdir/core/regress_big_polygon.sql
create table big_polygon_sliced as (
select ST_Subdivide(geom) As geom FROM big_polygon
