[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. 846301959476eb31cf19dd70d06dddcbdfb3ba56
git at osgeo.org
git at osgeo.org
Tue Oct 8 17:50:40 PDT 2019
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
via 846301959476eb31cf19dd70d06dddcbdfb3ba56 (commit)
from aa8861d05e1e1b62b1ea26e2a9434ce503df589a (commit)
revisions in full, below.
commit 846301959476eb31cf19dd70d06dddcbdfb3ba56
Author: Regina Obe <lr at pcorp.us>
Date: Tue Oct 8 20:50:35 2019 -0400
Take off disabling of inlining, also remove redundant make check in cmake builds
diff --git a/windows/mingw64/scripts/geos_make_install_check_branch.sh b/windows/mingw64/scripts/geos_make_install_check_branch.sh
index 74ab162..6b9eb39 100644
--- a/windows/mingw64/scripts/geos_make_install_check_branch.sh
+++ b/windows/mingw64/scripts/geos_make_install_check_branch.sh
@@ -51,9 +51,11 @@ if [[ "$MAKE_TYPE" == *cmake* ]] ; then
cd build${OS_BUILD}${MAKE_TYPE}
if [[ "${OS_BUILD}" == "64" ]] ; then
- cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DHAVE_LONG_LONG_INT_64=1 -DGEOS_ENABLE_INLINE=NO -DDISABLE_GEOS_INLINE=ON - ../${CMAKE_GEOS_VER}
+ #cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DHAVE_LONG_LONG_INT_64=1 -DGEOS_ENABLE_INLINE=NO -DDISABLE_GEOS_INLINE=ON - ../${CMAKE_GEOS_VER}
+ cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DHAVE_LONG_LONG_INT_64=1 - ../${CMAKE_GEOS_VER}
else
- cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DGEOS_ENABLE_INLINE=NO -DDISABLE_GEOS_INLINE=ON - ../${CMAKE_GEOS_VER}
+ #cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DGEOS_ENABLE_INLINE=NO -DDISABLE_GEOS_INLINE=ON - ../${CMAKE_GEOS_VER}
+ cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 - ../${CMAKE_GEOS_VER}
fi
make && make install
#make check
@@ -67,9 +69,11 @@ else
#mkdir -p build${OS_BUILD}${MAKE_TYPE}
#cd build${OS_BUILD}${MAKE_TYPE}
configure --build=${MINGHOST} --prefix=${SH_WORKSPACE}/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}
+ make && make install
+ make check
fi;
-make && make install
strip ${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll
-make check
Summary of changes:
windows/mingw64/scripts/geos_make_install_check_branch.sh | 12 ++++++++----
1 file changed, 8 insertions(+), 4 deletions(-)
hooks/post-receive
