[postgis-tickets] [PostGIS] #4535: buffer overflow WKB parser
    trac at osgeo.org
    Thu Oct 10 00:13:06 PDT 2019
 Reporter:  komzpa   |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.0.0
Component:  postgis  |    Version:  2.5.x
 Keywords:           |
 https://oss-fuzz.com/testcase-detail/5760493611909120
         +----------------------------------------Release Build
 Stacktrace----------------------------------------+
 Command:
 Bot: oss-fuzz-linux-zone2-host-t2dp-7
 Time ran: 0.0286400318146
 INFO: Seed: 3532246483
 INFO: Loaded 1 modules   (6940 inline 8-bit counters): 6940 [0x925a80,
 0x92759c),
 INFO: Loaded 1 PC tables (6940 PCs): 6940 [0x9275a0,0x942760),
 /mnt/scratch0/clusterfuzz/bot/builds/clusterfuzz-
 builds_postgis_e19bef733edf89095a9ecb61d62f7c8cdbe5dad1/revisions/wkb_import_fuzzer:
 Running 1 inputs 100 time(s) each.
 Running: /crash-d6bf73963fa5477e12879b836d42b6baba03049b
 ==1==ERROR: AddressSanitizer: heap-buffer-overflow on address
 0x6020000000b9 at pc 0x0000006100bc bp 0x7ffe6de51f30 sp 0x7ffe6de51f28
 READ of size 4 at 0x6020000000b9 thread T0
 SCARINESS: 17 (4-byte-read-heap-buffer-overflow)
     #0 0x6100bb in integer_from_wkb_state
 /src/postgis/liblwgeom/lwin_wkb.c:277:2
     #1 0x612443 in ptarray_from_wkb_state
 /src/postgis/liblwgeom/lwin_wkb.c:342:12
     #2 0x6113f7 in lwpoly_from_wkb_state
 /src/postgis/liblwgeom/lwin_wkb.c:521:20
     #3 0x611eda in lwgeom_from_wkb /src/postgis/liblwgeom/lwin_wkb.c:783:9
     #4 0x4c9d2d in LLVMFuzzerTestOneInput
 /src/postgis/fuzzers/wkb_import_fuzzer.cpp:116:22
     #5 0x51a546 in fuzzer::Fuzzer::ExecuteCallback(unsigned char const*,
 unsigned long) /src/libfuzzer/FuzzerLoop.cpp:556:15
     #6 0x4cb08f in fuzzer::RunOneTest(fuzzer::Fuzzer*, char const*,
 unsigned long) /src/libfuzzer/FuzzerDriver.cpp:292:6
     #7 0x4d8cf2 in fuzzer::FuzzerDriver(int*, char***, int (*)(unsigned
 char const*, unsigned long)) /src/libfuzzer/FuzzerDriver.cpp:774:9
     #8 0x4ca6d7 in main /src/libfuzzer/FuzzerMain.cpp:19:10
     #9 0x7f91e2a9e82f in __libc_start_main /build/glibc-
 LK5gWL/glibc-2.23/csu/libc-start.c:291
     #10 0x41e4e9 in _start
 0x6020000000b9 is located 0 bytes to the right of 9-byte region
 [0x6020000000b0,0x6020000000b9)
 allocated by thread T0 here:
     #0 0x4c647d in operator new[](unsigned long) /src/llvm/projects
 /compiler-rt/lib/asan/asan_new_delete.cpp:102:3
     #1 0x51a2f2 in fuzzer::Fuzzer::ExecuteCallback(unsigned char const*,
 unsigned long) /src/libfuzzer/FuzzerLoop.cpp:541:23
     #2 0x4cb08f in fuzzer::RunOneTest(fuzzer::Fuzzer*, char const*,
     #3 0x4d8cf2 in fuzzer::FuzzerDriver(int*, char***, int (*)(unsigned
     #4 0x4ca6d7 in main /src/libfuzzer/FuzzerMain.cpp:19:10
     #5 0x7f91e2a9e82f in __libc_start_main /build/glibc-
 SUMMARY: AddressSanitizer: heap-buffer-overflow
 (/mnt/scratch0/clusterfuzz/bot/builds/clusterfuzz-
 builds_postgis_e19bef733edf89095a9ecb61d62f7c8cdbe5dad1/revisions/wkb_import_fuzzer+0x6100bb)
 Shadow bytes around the buggy address:
   0x0c047fff7fc0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
   0x0c047fff7fd0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
   0x0c047fff7fe0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
   0x0c047fff7ff0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
   0x0c047fff8000: fa fa 00 00 fa fa 00 fa fa fa 00 fa fa fa 00 fa
 =>0x0c047fff8010: fa fa 00 01 fa fa 00[01]fa fa 00 fa fa fa fa fa
   0x0c047fff8020: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
   0x0c047fff8030: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
   0x0c047fff8040: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
   0x0c047fff8050: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
   0x0c047fff8060: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
 Shadow byte legend (one shadow byte represents 8 application bytes):
   Addressable:           00
   Partially addressable: 01 02 03 04 05 06 07
   Heap left redzone:       fa
   Freed heap region:       fd
   Stack left redzone:      f1
   Stack mid redzone:       f2
   Stack right redzone:     f3
   Stack after return:      f5
   Stack use after scope:   f8
   Global redzone:          f9
   Global init order:       f6
   Poisoned by user:        f7
   Container overflow:      fc
   Array cookie:            ac
   Intra object redzone:    bb
   ASan internal:           fe
   Left alloca redzone:     ca
   Right alloca redzone:    cb
   Shadow gap:              cc
 ==1==ABORTING
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4535>
