[postgis-tickets] r17900 - Fix leak in WKT collection parser
Raul
raul at rmr.ninja
Thu Oct 10 06:01:09 PDT 2019
Author: algunenano
Date: 2019-10-10 06:01:09 -0700 (Thu, 10 Oct 2019)
New Revision: 17900
trunk/NEWS
trunk/liblwgeom/cunit/cu_in_wkt.c
trunk/liblwgeom/lwin_wkt_parse.c
trunk/liblwgeom/lwin_wkt_parse.h
trunk/liblwgeom/lwin_wkt_parse.y
References #4537
Modified: trunk/NEWS
--- trunk/NEWS 2019-10-10 11:43:55 UTC (rev 17899)
+++ trunk/NEWS 2019-10-10 13:01:09 UTC (rev 17900)
@@ -9,6 +9,7 @@
* Major highlights *
- #4534, Fix leak in lwcurvepoly_from_wkb_state (Raúl Marín)
- #4536, Fix leak in lwcollection_from_wkb_state (Raúl Marín)
+ - #4537, Fix leak in WKT collection parser (Raúl Marín)
PostGIS 3.0.0rc1
2019/10/08
Modified: trunk/liblwgeom/cunit/cu_in_wkt.c
--- trunk/liblwgeom/cunit/cu_in_wkt.c 2019-10-10 11:43:55 UTC (rev 17899)
+++ trunk/liblwgeom/cunit/cu_in_wkt.c 2019-10-10 13:01:09 UTC (rev 17900)
@@ -57,6 +57,7 @@
if (p.errcode)
CU_ASSERT_EQUAL(rv, LW_FAILURE);
+ CU_ASSERT(!p.geom);
return strdup(p.message);
CU_ASSERT_EQUAL(rv, LW_SUCCESS);
@@ -361,7 +362,9 @@
wkt = "LINESTRING(1.1.1, 2.2.2)";
lwgeom_parser_result_init(&p);
rv = lwgeom_parse_wkt(&p, wkt, LW_PARSER_CHECK_ALL);
- CU_ASSERT_EQUAL( rv, LW_FAILURE );
+ CU_ASSERT( LW_FAILURE == rv );
+ CU_ASSERT( p.errcode );
+ CU_ASSERT( ! p.geom );
lwgeom_parser_result_free(&p);
wkt = "LINESTRING(1.1 .1, 2.2 .2)";
@@ -389,6 +392,14 @@
+static void test_wkt_leak(void)
+ char *wkt = "TINEMPTY,";
+ char *err = cu_wkt_in(wkt, WKT_EXTENDED);
+ CU_ASSERT_STRING_EQUAL(err, "parse error - invalid geometry");
+ lwfree(err);
** Used by test harness to register the tests in this file.
@@ -412,4 +423,5 @@
PG_ADD_TEST(suite, test_wkt_in_polyhedralsurface);
PG_ADD_TEST(suite, test_wkt_in_errlocation);
PG_ADD_TEST(suite, test_wkt_double);
+ PG_ADD_TEST(suite, test_wkt_leak);
Modified: trunk/liblwgeom/lwin_wkt_parse.c
--- trunk/liblwgeom/lwin_wkt_parse.c 2019-10-10 11:43:55 UTC (rev 17899)
+++ trunk/liblwgeom/lwin_wkt_parse.c 2019-10-10 13:01:09 UTC (rev 17900)
@@ -1,8 +1,9 @@
-/* A Bison parser, made by GNU Bison 3.2.2. */
+/* A Bison parser, made by GNU Bison 3.4. */
/* Bison implementation for Yacc-like parsers in C
- Copyright (C) 1984, 1989-1990, 2000-2015, 2018 Free Software Foundation, Inc.
+ Copyright (C) 1984, 1989-1990, 2000-2015, 2018-2019 Free Software Foundation,
+ Inc.
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
@@ -47,7 +48,7 @@
#define YYBISON 1
/* Bison version. */
-#define YYBISON_VERSION "3.2.2"
+#define YYBISON_VERSION "3.4"
/* Skeleton name. */
#define YYSKELETON_NAME "yacc.c"
@@ -74,7 +75,7 @@
#define yylloc wkt_yylloc
/* First part of user prologue. */
-#line 1 "lwin_wkt_parse.y" /* yacc.c:338 */
+#line 1 "lwin_wkt_parse.y"
/* WKT Parser */
@@ -155,11 +156,7 @@
global_parser_result.message = parser_error_messages[PARSER_ERROR_OTHER];
global_parser_result.errlocation = wkt_yylloc.last_column;
- /* Got a completed object parsed, but errored out after... */
- /* Due to junk after the valid WKT, eg: "POINT(1 1) foobar" */
- /* https://trac.osgeo.org/postgis/ticket/4273 */
- if ( global_parser_result.errcode && ! parse_rv )
+ else if (global_parser_result.geom)
lwgeom_free(global_parser_result.geom);
global_parser_result.geom = NULL;
@@ -186,7 +183,8 @@
-#line 190 "lwin_wkt_parse.c" /* yacc.c:338 */
+#line 187 "lwin_wkt_parse.c"
# ifndef YY_NULLPTR
# if defined __cplusplus
# if 201103L <= __cplusplus
@@ -207,8 +205,8 @@
# define YYERROR_VERBOSE 1
#endif
-/* In a future release of Bison, this section will be replaced
- by #include "lwin_wkt_parse.h". */
+/* Use api.header.include to #include this header
+ instead of duplicating it here. */
#ifndef YY_WKT_YY_LWIN_WKT_PARSE_H_INCLUDED
# define YY_WKT_YY_LWIN_WKT_PARSE_H_INCLUDED
/* Debug traces. */
@@ -276,10 +274,9 @@
/* Value type. */
#if ! defined YYSTYPE && ! defined YYSTYPE_IS_DECLARED
union YYSTYPE
-#line 116 "lwin_wkt_parse.y" /* yacc.c:353 */
+#line 112 "lwin_wkt_parse.y"
int integervalue;
double doublevalue;
@@ -288,9 +285,9 @@
POINT coordinatevalue;
POINTARRAY *ptarrayvalue;
-#line 292 "lwin_wkt_parse.c" /* yacc.c:353 */
+#line 289 "lwin_wkt_parse.c"
typedef union YYSTYPE YYSTYPE;
# define YYSTYPE_IS_TRIVIAL 1
# define YYSTYPE_IS_DECLARED 1
@@ -419,6 +416,8 @@
#endif
+#define YY_ASSERT(E) ((void) (0 && (E)))
#if ! defined yyoverflow || YYERROR_VERBOSE
/* The parser invokes alloca or malloc; define the necessary symbols. */
@@ -563,16 +562,16 @@
/* YYNSTATES -- Number of states. */
#define YYNSTATES 264
-/* YYTRANSLATE[YYX] -- Symbol number corresponding to YYX as returned
- by yylex, with out-of-bounds checking. */
#define YYUNDEFTOK 2
#define YYMAXUTOK 280
+/* YYTRANSLATE(TOKEN-NUM) -- Symbol number corresponding to TOKEN-NUM
+ as returned by yylex, with out-of-bounds checking. */
#define YYTRANSLATE(YYX) \
((unsigned) (YYX) <= YYMAXUTOK ? yytranslate[YYX] : YYUNDEFTOK)
/* YYTRANSLATE[TOKEN-NUM] -- Symbol number corresponding to TOKEN-NUM
- as returned by yylex, without out-of-bounds checking. */
+ as returned by yylex. */
static const yytype_uint8 yytranslate[] =
0, 2, 2, 2, 2, 2, 2, 2, 2, 2,
@@ -610,20 +609,20 @@
/* YYRLINE[YYN] -- Source line where rule number YYN was defined. */
static const yytype_uint16 yyrline[] =
- 0, 220, 220, 222, 226, 227, 228, 229, 230, 231,
- 232, 233, 234, 235, 236, 237, 238, 239, 240, 243,
- 245, 247, 249, 253, 255, 259, 261, 263, 265, 269,
- 271, 273, 275, 277, 279, 283, 285, 287, 289, 293,
- 295, 297, 299, 303, 305, 307, 309, 313, 315, 319,
- 321, 325, 327, 329, 331, 335, 337, 341, 344, 346,
- 348, 350, 354, 356, 360, 361, 362, 363, 366, 368,
- 372, 374, 378, 381, 384, 386, 388, 390, 394, 396,
- 398, 400, 402, 404, 408, 410, 412, 414, 418, 420,
- 422, 424, 426, 428, 430, 432, 436, 438, 440, 442,
- 446, 448, 452, 454, 456, 458, 462, 464, 466, 468,
- 472, 474, 478, 480, 484, 486, 488, 490, 494, 498,
- 500, 502, 504, 508, 510, 514, 516, 518, 522, 524,
- 526, 528, 532, 534, 538, 540, 542
+ 0, 216, 216, 218, 222, 223, 224, 225, 226, 227,
+ 228, 229, 230, 231, 232, 233, 234, 235, 236, 239,
+ 241, 243, 245, 249, 251, 255, 257, 259, 261, 265,
+ 267, 269, 271, 273, 275, 279, 281, 283, 285, 289,
+ 291, 293, 295, 299, 301, 303, 305, 309, 311, 315,
+ 317, 321, 323, 325, 327, 331, 333, 337, 340, 342,
+ 344, 346, 350, 352, 356, 357, 358, 359, 362, 364,
+ 368, 370, 374, 377, 380, 382, 384, 386, 390, 392,
+ 394, 396, 398, 400, 404, 406, 408, 410, 414, 416,
+ 418, 420, 422, 424, 426, 428, 432, 434, 436, 438,
+ 442, 444, 448, 450, 452, 454, 458, 460, 462, 464,
+ 468, 470, 474, 476, 480, 482, 484, 486, 490, 494,
+ 496, 498, 500, 504, 506, 510, 512, 514, 518, 520,
+ 522, 524, 528, 530, 534, 536, 538
#endif
@@ -912,22 +911,22 @@
#define YYRECOVERING() (!!yyerrstatus)
-#define YYBACKUP(Token, Value) \
-do \
- if (yychar == YYEMPTY) \
- yychar = (Token); \
- yylval = (Value); \
- YYPOPSTACK (yylen); \
- yystate = *yyssp; \
- goto yybackup; \
- else \
- yyerror (YY_("syntax error: cannot back up")); \
- YYERROR; \
-while (0)
+#define YYBACKUP(Token, Value) \
+ do \
+ if (yychar == YYEMPTY) \
+ yychar = (Token); \
+ yylval = (Value); \
+ YYPOPSTACK (yylen); \
+ yystate = *yyssp; \
+ goto yybackup; \
+ else \
+ yyerror (YY_("syntax error: cannot back up")); \
+ YYERROR; \
+ while (0)
/* Error token number */
#define YYTERROR 1
@@ -1110,7 +1109,7 @@
YYFPRINTF (stderr, " $%d = ", yyi + 1);
yy_symbol_print (stderr,
yystos[yyssp[yyi + 1 - yynrhs]],
- &(yyvsp[(yyi + 1) - (yynrhs)])
+ &yyvsp[(yyi + 1) - (yynrhs)]
, &(yylsp[(yyi + 1) - (yynrhs)]) );
YYFPRINTF (stderr, "\n");
@@ -1214,7 +1213,10 @@
case '\\':
if (*++yyp != '\\')
goto do_not_strip_quotes;
- /* Fall through. */
+ else
+ goto append;
+ append:
default:
if (yyres)
yyres[yyn] = *yyp;
@@ -1310,10 +1312,10 @@
yyarg[yycount++] = yytname[yyx];
YYSIZE_T yysize1 = yysize + yytnamerr (YY_NULLPTR, yytname[yyx]);
- if (! (yysize <= yysize1
- && yysize1 <= YYSTACK_ALLOC_MAXIMUM))
+ if (yysize <= yysize1 && yysize1 <= YYSTACK_ALLOC_MAXIMUM)
+ yysize = yysize1;
+ else
return 2;
- yysize = yysize1;
@@ -1337,9 +1339,10 @@
YYSIZE_T yysize1 = yysize + yystrlen (yyformat);
- if (! (yysize <= yysize1 && yysize1 <= YYSTACK_ALLOC_MAXIMUM))
+ yysize = yysize1;
+ else
return 2;
- yysize = yysize1;
if (*yymsg_alloc < yysize)
@@ -1389,223 +1392,222 @@
YY_IGNORE_MAYBE_UNINITIALIZED_BEGIN
switch (yytype)
- case 28: /* geometry_no_srid */
-#line 198 "lwin_wkt_parse.y" /* yacc.c:1254 */
+ case 28: /* geometry_no_srid */
+#line 194 "lwin_wkt_parse.y"
{ lwgeom_free(((*yyvaluep).geometryvalue)); }
-#line 1396 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1399 "lwin_wkt_parse.c"
break;
case 29: /* geometrycollection */
-#line 199 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 195 "lwin_wkt_parse.y"
-#line 1402 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1405 "lwin_wkt_parse.c"
break;
case 31: /* multisurface */
-#line 206 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 202 "lwin_wkt_parse.y"
-#line 1408 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1411 "lwin_wkt_parse.c"
break;
case 32: /* surface_list */
-#line 185 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 181 "lwin_wkt_parse.y"
-#line 1414 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1417 "lwin_wkt_parse.c"
break;
case 33: /* tin */
-#line 213 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 209 "lwin_wkt_parse.y"
-#line 1420 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1423 "lwin_wkt_parse.c"
break;
case 34: /* polyhedralsurface */
-#line 212 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 208 "lwin_wkt_parse.y"
-#line 1426 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1429 "lwin_wkt_parse.c"
break;
case 35: /* multipolygon */
-#line 205 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 201 "lwin_wkt_parse.y"
-#line 1432 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1435 "lwin_wkt_parse.c"
break;
case 36: /* polygon_list */
-#line 186 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 182 "lwin_wkt_parse.y"
-#line 1438 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1441 "lwin_wkt_parse.c"
break;
case 37: /* patch_list */
-#line 187 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 183 "lwin_wkt_parse.y"
-#line 1444 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1447 "lwin_wkt_parse.c"
break;
case 38: /* polygon */
-#line 209 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 205 "lwin_wkt_parse.y"
-#line 1450 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1453 "lwin_wkt_parse.c"
break;
case 39: /* polygon_untagged */
-#line 211 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 207 "lwin_wkt_parse.y"
-#line 1456 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1459 "lwin_wkt_parse.c"
break;
case 40: /* patch */
-#line 210 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 206 "lwin_wkt_parse.y"
-#line 1462 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1465 "lwin_wkt_parse.c"
break;
case 41: /* curvepolygon */
-#line 196 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 192 "lwin_wkt_parse.y"
-#line 1468 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1471 "lwin_wkt_parse.c"
break;
case 42: /* curvering_list */
-#line 183 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 179 "lwin_wkt_parse.y"
-#line 1474 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1477 "lwin_wkt_parse.c"
break;
case 43: /* curvering */
-#line 197 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 193 "lwin_wkt_parse.y"
-#line 1480 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1483 "lwin_wkt_parse.c"
break;
case 44: /* patchring_list */
-#line 193 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 189 "lwin_wkt_parse.y"
-#line 1486 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1489 "lwin_wkt_parse.c"
break;
case 45: /* ring_list */
-#line 192 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 188 "lwin_wkt_parse.y"
-#line 1492 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1495 "lwin_wkt_parse.c"
break;
case 46: /* patchring */
-#line 182 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 178 "lwin_wkt_parse.y"
{ ptarray_free(((*yyvaluep).ptarrayvalue)); }
-#line 1498 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1501 "lwin_wkt_parse.c"
break;
case 47: /* ring */
-#line 181 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 177 "lwin_wkt_parse.y"
-#line 1504 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1507 "lwin_wkt_parse.c"
break;
case 48: /* compoundcurve */
-#line 195 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 191 "lwin_wkt_parse.y"
-#line 1510 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1513 "lwin_wkt_parse.c"
break;
case 49: /* compound_list */
-#line 191 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 187 "lwin_wkt_parse.y"
-#line 1516 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1519 "lwin_wkt_parse.c"
break;
case 50: /* multicurve */
-#line 202 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 198 "lwin_wkt_parse.y"
-#line 1522 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1525 "lwin_wkt_parse.c"
break;
case 51: /* curve_list */
-#line 190 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 186 "lwin_wkt_parse.y"
-#line 1528 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1531 "lwin_wkt_parse.c"
break;
case 52: /* multilinestring */
-#line 203 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 199 "lwin_wkt_parse.y"
-#line 1534 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1537 "lwin_wkt_parse.c"
break;
case 53: /* linestring_list */
-#line 189 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 185 "lwin_wkt_parse.y"
-#line 1540 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1543 "lwin_wkt_parse.c"
break;
case 54: /* circularstring */
-#line 194 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 190 "lwin_wkt_parse.y"
-#line 1546 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1549 "lwin_wkt_parse.c"
break;
case 55: /* linestring */
-#line 200 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 196 "lwin_wkt_parse.y"
-#line 1552 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1555 "lwin_wkt_parse.c"
break;
case 56: /* linestring_untagged */
-#line 201 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 197 "lwin_wkt_parse.y"
-#line 1558 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1561 "lwin_wkt_parse.c"
break;
case 57: /* triangle_list */
-#line 184 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 180 "lwin_wkt_parse.y"
-#line 1564 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1567 "lwin_wkt_parse.c"
break;
case 58: /* triangle */
-#line 214 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 210 "lwin_wkt_parse.y"
-#line 1570 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1573 "lwin_wkt_parse.c"
break;
case 59: /* triangle_untagged */
-#line 215 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 211 "lwin_wkt_parse.y"
-#line 1576 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1579 "lwin_wkt_parse.c"
break;
case 60: /* multipoint */
-#line 204 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 200 "lwin_wkt_parse.y"
-#line 1582 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1585 "lwin_wkt_parse.c"
break;
case 61: /* point_list */
-#line 188 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 184 "lwin_wkt_parse.y"
-#line 1588 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1591 "lwin_wkt_parse.c"
break;
case 62: /* point_untagged */
-#line 208 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 204 "lwin_wkt_parse.y"
-#line 1594 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1597 "lwin_wkt_parse.c"
break;
case 63: /* point */
-#line 207 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 203 "lwin_wkt_parse.y"
-#line 1600 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1603 "lwin_wkt_parse.c"
break;
case 64: /* ptarray */
-#line 180 "lwin_wkt_parse.y" /* yacc.c:1254 */
+#line 176 "lwin_wkt_parse.y"
-#line 1606 "lwin_wkt_parse.c" /* yacc.c:1254 */
+#line 1609 "lwin_wkt_parse.c"
break;
default:
break;
@@ -1705,23 +1707,33 @@
yylsp[0] = yylloc;
goto yysetstate;
-| yynewstate -- Push a new state, which is found in yystate. |
+| yynewstate -- push a new state, which is found in yystate. |
- yynewstate:
+yynewstate:
/* In all cases, when you get here, the value and location stacks
have just been pushed. So pushing a state here evens the stacks. */
yyssp++;
- yysetstate:
+| yynewstate -- set current state (the top of the stack) to yystate. |
+yysetstate:
+ YYDPRINTF ((stderr, "Entering state %d\n", yystate));
+ YY_ASSERT (0 <= yystate && yystate < YYNSTATES);
*yyssp = (yytype_int16) yystate;
if (yyss + yystacksize - 1 <= yyssp)
+#if !defined yyoverflow && !defined YYSTACK_RELOCATE
+ goto yyexhaustedlab;
+#else
/* Get the current used size of the three stacks, in elements. */
YYSIZE_T yysize = (YYSIZE_T) (yyssp - yyss + 1);
-#ifdef yyoverflow
+# if defined yyoverflow
/* Give user a chance to reallocate the stack. Use copies of
these so that the &'s don't force the real ones into
@@ -1743,10 +1755,7 @@
yyvs = yyvs1;
yyls = yyls1;
-#else /* no yyoverflow */
-# ifndef YYSTACK_RELOCATE
- goto yyexhaustedlab;
-# else
+# else /* defined YYSTACK_RELOCATE */
/* Extend the stack our own way. */
if (YYMAXDEPTH <= yystacksize)
@@ -1763,12 +1772,11 @@
YYSTACK_RELOCATE (yyss_alloc, yyss);
YYSTACK_RELOCATE (yyvs_alloc, yyvs);
YYSTACK_RELOCATE (yyls_alloc, yyls);
-# undef YYSTACK_RELOCATE
+# undef YYSTACK_RELOCATE
if (yyss1 != yyssa)
YYSTACK_FREE (yyss1);
# endif
-#endif /* no yyoverflow */
yyssp = yyss + yysize - 1;
yyvsp = yyvs + yysize - 1;
@@ -1780,19 +1788,18 @@
YYABORT;
+#endif /* !defined yyoverflow && !defined YYSTACK_RELOCATE */
- YYDPRINTF ((stderr, "Entering state %d\n", yystate));
if (yystate == YYFINAL)
YYACCEPT;
goto yybackup;
| yybackup. |
yybackup:
/* Do appropriate processing given the current state. Read a
lookahead token if we need one and don't already have one. */
@@ -1865,7 +1872,7 @@
-| yyreduce -- Do a reduction. |
+| yyreduce -- do a reduction. |
yyreduce:
/* yyn is the number of a rule to reduce with. */
@@ -1887,818 +1894,819 @@
YY_REDUCE_PRINT (yyn);
switch (yyn)
- case 2:
-#line 221 "lwin_wkt_parse.y" /* yacc.c:1645 */
+ case 2:
+#line 217 "lwin_wkt_parse.y"
{ wkt_parser_geometry_new((yyvsp[0].geometryvalue), SRID_UNKNOWN); WKT_ERROR(); }
-#line 1894 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1901 "lwin_wkt_parse.c"
break;
case 3:
-#line 223 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 219 "lwin_wkt_parse.y"
{ wkt_parser_geometry_new((yyvsp[0].geometryvalue), (yyvsp[-2].integervalue)); WKT_ERROR(); }
-#line 1900 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1907 "lwin_wkt_parse.c"
break;
case 4:
-#line 226 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 222 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = (yyvsp[0].geometryvalue); }
-#line 1906 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1913 "lwin_wkt_parse.c"
break;
case 5:
-#line 227 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 223 "lwin_wkt_parse.y"
-#line 1912 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1919 "lwin_wkt_parse.c"
break;
case 6:
-#line 228 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 224 "lwin_wkt_parse.y"
-#line 1918 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1925 "lwin_wkt_parse.c"
break;
case 7:
-#line 229 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 225 "lwin_wkt_parse.y"
-#line 1924 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1931 "lwin_wkt_parse.c"
break;
case 8:
-#line 230 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 226 "lwin_wkt_parse.y"
-#line 1930 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1937 "lwin_wkt_parse.c"
break;
case 9:
-#line 231 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 227 "lwin_wkt_parse.y"
-#line 1936 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1943 "lwin_wkt_parse.c"
break;
case 10:
-#line 232 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 228 "lwin_wkt_parse.y"
-#line 1942 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1949 "lwin_wkt_parse.c"
break;
case 11:
-#line 233 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 229 "lwin_wkt_parse.y"
-#line 1948 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1955 "lwin_wkt_parse.c"
break;
case 12:
-#line 234 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 230 "lwin_wkt_parse.y"
-#line 1954 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1961 "lwin_wkt_parse.c"
break;
case 13:
-#line 235 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 231 "lwin_wkt_parse.y"
-#line 1960 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1967 "lwin_wkt_parse.c"
break;
case 14:
-#line 236 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 232 "lwin_wkt_parse.y"
-#line 1966 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1973 "lwin_wkt_parse.c"
break;
case 15:
-#line 237 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 233 "lwin_wkt_parse.y"
-#line 1972 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1979 "lwin_wkt_parse.c"
break;
case 16:
-#line 238 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 234 "lwin_wkt_parse.y"
-#line 1978 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1985 "lwin_wkt_parse.c"
break;
case 17:
-#line 239 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 235 "lwin_wkt_parse.y"
-#line 1984 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1991 "lwin_wkt_parse.c"
break;
case 18:
-#line 240 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 236 "lwin_wkt_parse.y"
-#line 1990 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 1997 "lwin_wkt_parse.c"
break;
case 19:
-#line 244 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 240 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COLLECTIONTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 1996 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2003 "lwin_wkt_parse.c"
break;
case 20:
-#line 246 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 242 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COLLECTIONTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2002 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2009 "lwin_wkt_parse.c"
break;
case 21:
-#line 248 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 244 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COLLECTIONTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2008 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2015 "lwin_wkt_parse.c"
break;
case 22:
-#line 250 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 246 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COLLECTIONTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2014 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2021 "lwin_wkt_parse.c"
break;
case 23:
-#line 254 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 250 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_add_geom((yyvsp[-2].geometryvalue),(yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2020 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2027 "lwin_wkt_parse.c"
break;
case 24:
-#line 256 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 252 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_new((yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2026 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2033 "lwin_wkt_parse.c"
break;
case 25:
-#line 260 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 256 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTISURFACETYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2032 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2039 "lwin_wkt_parse.c"
break;
case 26:
-#line 262 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 258 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTISURFACETYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2038 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2045 "lwin_wkt_parse.c"
break;
case 27:
-#line 264 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 260 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTISURFACETYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2044 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2051 "lwin_wkt_parse.c"
break;
case 28:
-#line 266 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 262 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTISURFACETYPE, NULL, NULL); WKT_ERROR(); }
-#line 2050 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2057 "lwin_wkt_parse.c"
break;
case 29:
-#line 270 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 266 "lwin_wkt_parse.y"
-#line 2056 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2063 "lwin_wkt_parse.c"
break;
case 30:
-#line 272 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 268 "lwin_wkt_parse.y"
-#line 2062 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2069 "lwin_wkt_parse.c"
break;
case 31:
-#line 274 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 270 "lwin_wkt_parse.y"
-#line 2068 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2075 "lwin_wkt_parse.c"
break;
case 32:
-#line 276 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 272 "lwin_wkt_parse.y"
-#line 2074 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2081 "lwin_wkt_parse.c"
break;
case 33:
-#line 278 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 274 "lwin_wkt_parse.y"
-#line 2080 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2087 "lwin_wkt_parse.c"
break;
case 34:
-#line 280 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 276 "lwin_wkt_parse.y"
-#line 2086 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2093 "lwin_wkt_parse.c"
break;
case 35:
-#line 284 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 280 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(TINTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2092 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2099 "lwin_wkt_parse.c"
break;
case 36:
-#line 286 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 282 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(TINTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2098 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2105 "lwin_wkt_parse.c"
break;
case 37:
-#line 288 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 284 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(TINTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2104 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2111 "lwin_wkt_parse.c"
break;
case 38:
-#line 290 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 286 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(TINTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2110 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2117 "lwin_wkt_parse.c"
break;
case 39:
-#line 294 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 290 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(POLYHEDRALSURFACETYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2116 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2123 "lwin_wkt_parse.c"
break;
case 40:
-#line 296 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 292 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(POLYHEDRALSURFACETYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2122 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2129 "lwin_wkt_parse.c"
break;
case 41:
-#line 298 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 294 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(POLYHEDRALSURFACETYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2128 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2135 "lwin_wkt_parse.c"
break;
case 42:
-#line 300 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 296 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(POLYHEDRALSURFACETYPE, NULL, NULL); WKT_ERROR(); }
-#line 2134 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2141 "lwin_wkt_parse.c"
break;
case 43:
-#line 304 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 300 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOLYGONTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2140 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2147 "lwin_wkt_parse.c"
break;
case 44:
-#line 306 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 302 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOLYGONTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2146 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2153 "lwin_wkt_parse.c"
break;
case 45:
-#line 308 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 304 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOLYGONTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2152 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2159 "lwin_wkt_parse.c"
break;
case 46:
-#line 310 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 306 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOLYGONTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2158 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2165 "lwin_wkt_parse.c"
break;
case 47:
-#line 314 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 310 "lwin_wkt_parse.y"
-#line 2164 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2171 "lwin_wkt_parse.c"
break;
case 48:
-#line 316 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 312 "lwin_wkt_parse.y"
-#line 2170 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2177 "lwin_wkt_parse.c"
break;
case 49:
-#line 320 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 316 "lwin_wkt_parse.y"
-#line 2176 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2183 "lwin_wkt_parse.c"
break;
case 50:
-#line 322 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 318 "lwin_wkt_parse.y"
-#line 2182 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2189 "lwin_wkt_parse.c"
break;
case 51:
-#line 326 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 322 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_polygon_finalize((yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2188 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2195 "lwin_wkt_parse.c"
break;
case 52:
-#line 328 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 324 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_polygon_finalize((yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2194 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2201 "lwin_wkt_parse.c"
break;
case 53:
-#line 330 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 326 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_polygon_finalize(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2200 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2207 "lwin_wkt_parse.c"
break;
case 54:
-#line 332 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 328 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_polygon_finalize(NULL, NULL); WKT_ERROR(); }
-#line 2206 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2213 "lwin_wkt_parse.c"
break;
case 55:
-#line 336 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 332 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = (yyvsp[-1].geometryvalue); }
-#line 2212 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2219 "lwin_wkt_parse.c"
break;
case 56:
-#line 338 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 334 "lwin_wkt_parse.y"
-#line 2218 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2225 "lwin_wkt_parse.c"
break;
case 57:
-#line 341 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 337 "lwin_wkt_parse.y"
-#line 2224 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2231 "lwin_wkt_parse.c"
break;
case 58:
-#line 345 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 341 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_finalize((yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2230 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2237 "lwin_wkt_parse.c"
break;
case 59:
-#line 347 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 343 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_finalize((yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2236 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2243 "lwin_wkt_parse.c"
break;
case 60:
-#line 349 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 345 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_finalize(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2242 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2249 "lwin_wkt_parse.c"
break;
case 61:
-#line 351 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 347 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_finalize(NULL, NULL); WKT_ERROR(); }
-#line 2248 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2255 "lwin_wkt_parse.c"
break;
case 62:
-#line 355 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 351 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_add_ring((yyvsp[-2].geometryvalue),(yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2254 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2261 "lwin_wkt_parse.c"
break;
case 63:
-#line 357 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 353 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_new((yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2260 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2267 "lwin_wkt_parse.c"
break;
case 64:
-#line 360 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 356 "lwin_wkt_parse.y"
-#line 2266 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2273 "lwin_wkt_parse.c"
break;
case 65:
-#line 361 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 357 "lwin_wkt_parse.y"
-#line 2272 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2279 "lwin_wkt_parse.c"
break;
case 66:
-#line 362 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 358 "lwin_wkt_parse.y"
-#line 2278 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2285 "lwin_wkt_parse.c"
break;
case 67:
-#line 363 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 359 "lwin_wkt_parse.y"
-#line 2284 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2291 "lwin_wkt_parse.c"
break;
case 68:
-#line 367 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 363 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_polygon_add_ring((yyvsp[-2].geometryvalue),(yyvsp[0].ptarrayvalue),'Z'); WKT_ERROR(); }
-#line 2290 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2297 "lwin_wkt_parse.c"
break;
case 69:
-#line 369 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 365 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_polygon_new((yyvsp[0].ptarrayvalue),'Z'); WKT_ERROR(); }
-#line 2296 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2303 "lwin_wkt_parse.c"
break;
case 70:
-#line 373 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 369 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_polygon_add_ring((yyvsp[-2].geometryvalue),(yyvsp[0].ptarrayvalue),'2'); WKT_ERROR(); }
-#line 2302 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2309 "lwin_wkt_parse.c"
break;
case 71:
-#line 375 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 371 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_polygon_new((yyvsp[0].ptarrayvalue),'2'); WKT_ERROR(); }
-#line 2308 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2315 "lwin_wkt_parse.c"
break;
case 72:
-#line 378 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 374 "lwin_wkt_parse.y"
{ (yyval.ptarrayvalue) = (yyvsp[-1].ptarrayvalue); }
-#line 2314 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2321 "lwin_wkt_parse.c"
break;
case 73:
-#line 381 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 377 "lwin_wkt_parse.y"
-#line 2320 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2327 "lwin_wkt_parse.c"
break;
case 74:
-#line 385 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 381 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COMPOUNDTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2326 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2333 "lwin_wkt_parse.c"
break;
case 75:
-#line 387 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 383 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COMPOUNDTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2332 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2339 "lwin_wkt_parse.c"
break;
case 76:
-#line 389 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 385 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COMPOUNDTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2338 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2345 "lwin_wkt_parse.c"
break;
case 77:
-#line 391 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 387 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COMPOUNDTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2344 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2351 "lwin_wkt_parse.c"
break;
case 78:
-#line 395 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 391 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_compound_add_geom((yyvsp[-2].geometryvalue),(yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2350 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2357 "lwin_wkt_parse.c"
break;
case 79:
-#line 397 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 393 "lwin_wkt_parse.y"
-#line 2356 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2363 "lwin_wkt_parse.c"
break;
case 80:
-#line 399 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 395 "lwin_wkt_parse.y"
-#line 2362 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2369 "lwin_wkt_parse.c"
break;
case 81:
-#line 401 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 397 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_compound_new((yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2368 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2375 "lwin_wkt_parse.c"
break;
case 82:
-#line 403 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 399 "lwin_wkt_parse.y"
-#line 2374 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2381 "lwin_wkt_parse.c"
break;
case 83:
-#line 405 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 401 "lwin_wkt_parse.y"
-#line 2380 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2387 "lwin_wkt_parse.c"
break;
case 84:
-#line 409 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 405 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTICURVETYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2386 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2393 "lwin_wkt_parse.c"
break;
case 85:
-#line 411 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 407 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTICURVETYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2392 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2399 "lwin_wkt_parse.c"
break;
case 86:
-#line 413 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 409 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTICURVETYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2398 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2405 "lwin_wkt_parse.c"
break;
case 87:
-#line 415 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 411 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTICURVETYPE, NULL, NULL); WKT_ERROR(); }
-#line 2404 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2411 "lwin_wkt_parse.c"
break;
case 88:
-#line 419 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 415 "lwin_wkt_parse.y"
-#line 2410 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2417 "lwin_wkt_parse.c"
break;
case 89:
-#line 421 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 417 "lwin_wkt_parse.y"
-#line 2416 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2423 "lwin_wkt_parse.c"
break;
case 90:
-#line 423 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 419 "lwin_wkt_parse.y"
-#line 2422 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2429 "lwin_wkt_parse.c"
break;
case 91:
-#line 425 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 421 "lwin_wkt_parse.y"
-#line 2428 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2435 "lwin_wkt_parse.c"
break;
case 92:
-#line 427 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 423 "lwin_wkt_parse.y"
-#line 2434 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2441 "lwin_wkt_parse.c"
break;
case 93:
-#line 429 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 425 "lwin_wkt_parse.y"
-#line 2440 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2447 "lwin_wkt_parse.c"
break;
case 94:
-#line 431 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 427 "lwin_wkt_parse.y"
-#line 2446 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2453 "lwin_wkt_parse.c"
break;
case 95:
-#line 433 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 429 "lwin_wkt_parse.y"
-#line 2452 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2459 "lwin_wkt_parse.c"
break;
case 96:
-#line 437 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 433 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTILINETYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2458 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2465 "lwin_wkt_parse.c"
break;
case 97:
-#line 439 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 435 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTILINETYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2464 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2471 "lwin_wkt_parse.c"
break;
case 98:
-#line 441 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 437 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTILINETYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2470 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2477 "lwin_wkt_parse.c"
break;
case 99:
-#line 443 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 439 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTILINETYPE, NULL, NULL); WKT_ERROR(); }
-#line 2476 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2483 "lwin_wkt_parse.c"
break;
case 100:
-#line 447 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 443 "lwin_wkt_parse.y"
-#line 2482 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2489 "lwin_wkt_parse.c"
break;
case 101:
-#line 449 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 445 "lwin_wkt_parse.y"
-#line 2488 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2495 "lwin_wkt_parse.c"
break;
case 102:
-#line 453 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 449 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_circularstring_new((yyvsp[-1].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2494 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2501 "lwin_wkt_parse.c"
break;
case 103:
-#line 455 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 451 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_circularstring_new((yyvsp[-1].ptarrayvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2500 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2507 "lwin_wkt_parse.c"
break;
case 104:
-#line 457 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 453 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_circularstring_new(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2506 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2513 "lwin_wkt_parse.c"
break;
case 105:
-#line 459 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 455 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_circularstring_new(NULL, NULL); WKT_ERROR(); }
-#line 2512 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2519 "lwin_wkt_parse.c"
break;
case 106:
-#line 463 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 459 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_linestring_new((yyvsp[-1].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2518 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2525 "lwin_wkt_parse.c"
break;
case 107:
-#line 465 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 461 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_linestring_new((yyvsp[-1].ptarrayvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2524 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2531 "lwin_wkt_parse.c"
break;
case 108:
-#line 467 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 463 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_linestring_new(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2530 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2537 "lwin_wkt_parse.c"
break;
case 109:
-#line 469 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 465 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_linestring_new(NULL, NULL); WKT_ERROR(); }
-#line 2536 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2543 "lwin_wkt_parse.c"
break;
case 110:
-#line 473 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 469 "lwin_wkt_parse.y"
-#line 2542 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2549 "lwin_wkt_parse.c"
break;
case 111:
-#line 475 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 471 "lwin_wkt_parse.y"
-#line 2548 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2555 "lwin_wkt_parse.c"
break;
case 112:
-#line 479 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 475 "lwin_wkt_parse.y"
-#line 2554 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2561 "lwin_wkt_parse.c"
break;
case 113:
-#line 481 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 477 "lwin_wkt_parse.y"
-#line 2560 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2567 "lwin_wkt_parse.c"
break;
case 114:
-#line 485 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 481 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_triangle_new((yyvsp[-2].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2566 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2573 "lwin_wkt_parse.c"
break;
case 115:
-#line 487 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 483 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_triangle_new((yyvsp[-2].ptarrayvalue), (yyvsp[-5].stringvalue)); WKT_ERROR(); }
-#line 2572 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2579 "lwin_wkt_parse.c"
break;
case 116:
-#line 489 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 485 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_triangle_new(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2578 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2585 "lwin_wkt_parse.c"
break;
case 117:
-#line 491 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 487 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_triangle_new(NULL, NULL); WKT_ERROR(); }
-#line 2584 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2591 "lwin_wkt_parse.c"
break;
case 118:
-#line 495 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 491 "lwin_wkt_parse.y"
-#line 2590 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2597 "lwin_wkt_parse.c"
break;
case 119:
-#line 499 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 495 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOINTTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2596 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2603 "lwin_wkt_parse.c"
break;
case 120:
-#line 501 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 497 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOINTTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2602 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2609 "lwin_wkt_parse.c"
break;
case 121:
-#line 503 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 499 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOINTTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2608 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2615 "lwin_wkt_parse.c"
break;
case 122:
-#line 505 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 501 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOINTTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2614 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2621 "lwin_wkt_parse.c"
break;
case 123:
-#line 509 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 505 "lwin_wkt_parse.y"
-#line 2620 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2627 "lwin_wkt_parse.c"
break;
case 124:
-#line 511 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 507 "lwin_wkt_parse.y"
-#line 2626 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2633 "lwin_wkt_parse.c"
break;
case 125:
-#line 515 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 511 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_point_new(wkt_parser_ptarray_new((yyvsp[0].coordinatevalue)),NULL); WKT_ERROR(); }
-#line 2632 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2639 "lwin_wkt_parse.c"
break;
case 126:
-#line 517 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 513 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_point_new(wkt_parser_ptarray_new((yyvsp[-1].coordinatevalue)),NULL); WKT_ERROR(); }
-#line 2638 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2645 "lwin_wkt_parse.c"
break;
case 127:
-#line 519 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 515 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_point_new(NULL, NULL); WKT_ERROR(); }
-#line 2644 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2651 "lwin_wkt_parse.c"
break;
case 128:
-#line 523 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 519 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_point_new((yyvsp[-1].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2650 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2657 "lwin_wkt_parse.c"
break;
case 129:
-#line 525 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 521 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_point_new((yyvsp[-1].ptarrayvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2656 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2663 "lwin_wkt_parse.c"
break;
case 130:
-#line 527 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 523 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_point_new(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2662 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2669 "lwin_wkt_parse.c"
break;
case 131:
-#line 529 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 525 "lwin_wkt_parse.y"
{ (yyval.geometryvalue) = wkt_parser_point_new(NULL,NULL); WKT_ERROR(); }
-#line 2668 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2675 "lwin_wkt_parse.c"
break;
case 132:
-#line 533 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 529 "lwin_wkt_parse.y"
{ (yyval.ptarrayvalue) = wkt_parser_ptarray_add_coord((yyvsp[-2].ptarrayvalue), (yyvsp[0].coordinatevalue)); WKT_ERROR(); }
-#line 2674 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2681 "lwin_wkt_parse.c"
break;
case 133:
-#line 535 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 531 "lwin_wkt_parse.y"
{ (yyval.ptarrayvalue) = wkt_parser_ptarray_new((yyvsp[0].coordinatevalue)); WKT_ERROR(); }
-#line 2680 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2687 "lwin_wkt_parse.c"
break;
case 134:
-#line 539 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 535 "lwin_wkt_parse.y"
{ (yyval.coordinatevalue) = wkt_parser_coord_2((yyvsp[-1].doublevalue), (yyvsp[0].doublevalue)); WKT_ERROR(); }
-#line 2686 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2693 "lwin_wkt_parse.c"
break;
case 135:
-#line 541 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 537 "lwin_wkt_parse.y"
{ (yyval.coordinatevalue) = wkt_parser_coord_3((yyvsp[-2].doublevalue), (yyvsp[-1].doublevalue), (yyvsp[0].doublevalue)); WKT_ERROR(); }
-#line 2692 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2699 "lwin_wkt_parse.c"
break;
case 136:
-#line 543 "lwin_wkt_parse.y" /* yacc.c:1645 */
+#line 539 "lwin_wkt_parse.y"
{ (yyval.coordinatevalue) = wkt_parser_coord_4((yyvsp[-3].doublevalue), (yyvsp[-2].doublevalue), (yyvsp[-1].doublevalue), (yyvsp[0].doublevalue)); WKT_ERROR(); }
-#line 2698 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2705 "lwin_wkt_parse.c"
break;
-#line 2702 "lwin_wkt_parse.c" /* yacc.c:1645 */
+#line 2709 "lwin_wkt_parse.c"
default: break;
/* User semantic actions sometimes alter yychar, and that requires
@@ -2813,13 +2821,11 @@
| yyerrorlab -- error raised explicitly by YYERROR. |
yyerrorlab:
+ /* Pacify compilers when the user code never invokes YYERROR and the
+ label yyerrorlab therefore never appears in user code. */
+ if (0)
+ YYERROR;
- /* Pacify compilers like GCC when the user code never invokes
- YYERROR and the label yyerrorlab therefore never appears in user
- code. */
- if (/*CONSTCOND*/ 0)
- goto yyerrorlab;
/* Do not reclaim the symbols of the rule whose action triggered
this YYERROR. */
YYPOPSTACK (yylen);
@@ -2885,6 +2891,7 @@
yyresult = 0;
goto yyreturn;
| yyabortlab -- YYABORT comes here. |
@@ -2892,6 +2899,7 @@
yyresult = 1;
goto yyreturn;
#if !defined yyoverflow || YYERROR_VERBOSE
| yyexhaustedlab -- memory exhaustion comes here. |
@@ -2902,6 +2910,10 @@
/* Fall through. */
#endif
+| yyreturn -- parsing is finished, return the result. |
yyreturn:
if (yychar != YYEMPTY)
@@ -2931,6 +2943,6 @@
#endif
return yyresult;
-#line 545 "lwin_wkt_parse.y" /* yacc.c:1903 */
+#line 541 "lwin_wkt_parse.y"
Modified: trunk/liblwgeom/lwin_wkt_parse.h
--- trunk/liblwgeom/lwin_wkt_parse.h 2019-10-10 11:43:55 UTC (rev 17899)
+++ trunk/liblwgeom/lwin_wkt_parse.h 2019-10-10 13:01:09 UTC (rev 17900)
@@ -1,8 +1,9 @@
/* Bison interface for Yacc-like parsers in C
+ Inc.
@@ -100,10 +101,9 @@
/* Value type. */
union YYSTYPE
-#line 116 "lwin_wkt_parse.y" /* yacc.c:1906 */
int integervalue;
double doublevalue;
@@ -112,9 +112,9 @@
-#line 116 "lwin_wkt_parse.h" /* yacc.c:1906 */
+#line 116 "lwin_wkt_parse.h"
Modified: trunk/liblwgeom/lwin_wkt_parse.y
--- trunk/liblwgeom/lwin_wkt_parse.y 2019-10-10 11:43:55 UTC (rev 17899)
+++ trunk/liblwgeom/lwin_wkt_parse.y 2019-10-10 13:01:09 UTC (rev 17900)
@@ -78,11 +78,7 @@
