[postgis-tickets] [PostGIS] #4535: buffer overflow WKB parser
trac at osgeo.org
Thu Oct 10 09:58:47 PDT 2019
Reporter: komzpa | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: 2.5.x
Resolution: fixed | Keywords:
Changes (by Raul Marin):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"17904" 17904]:
#!CommitTicketReference repository="" revision="17904"
WKB: Avoid buffer overflow
This only happens when not running under PG context, as
lwerror continues execution and that means that even after
detecting there isn't enough bytes still try to read from the buffer
Closes #4535
Closes https://github.com/postgis/postgis/pull/495
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4535#comment:3>
