[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. bc06d22b7541cb8bd8f9ad434c11a21541380a12
Sandro Santilli
strk at kbt.io
Thu Oct 10 23:35:04 PDT 2019
On Thu, Oct 10, 2019 at 01:44:52PM -0700, git at osgeo.org wrote:
> commit bc06d22b7541cb8bd8f9ad434c11a21541380a12
> Author: Regina Obe <lr at pcorp.us>
> Date: Thu Oct 10 16:44:48 2019 -0400
> try again
> diff --git a/windows/mingw64/scripts/geos_make_install_check_branch.sh b/windows/mingw64/scripts/geos_make_install_check_branch.sh
> index 053a7db..657791f 100644
> --- a/windows/mingw64/scripts/geos_make_install_check_branch.sh
> +++ b/windows/mingw64/scripts/geos_make_install_check_branch.sh
> @@ -50,7 +50,7 @@ if [[ "$MAKE_TYPE" == *cmake* ]] ; then
> mkdir -p build${OS_BUILD}${MAKE_TYPE}
> cd build${OS_BUILD}${MAKE_TYPE}
> export GEOS_ENABLE_INLINE=ON #for older geos
> - if [[ "${DISABLE_GEOS_INLINE}" == ""]]; then
> + if [[ "${DISABLE_GEOS_INLINE}" == "" ]] ; then
This is posix compliant:
if [ "${DISABLE_GEOS_INLINE}" = "" ]; then
--strk;
