[postgis-tickets] r17907 - Prepping for PostGIS 3.0.0rc2 release
Regina Obe lr at pcorp.us
Sat Oct 12 07:57:30 PDT 2019
Author: robe
Date: 2019-10-12 19:57:29 -0700 (Sat, 12 Oct 2019)
New Revision: 17907
   trunk/ChangeLog
   trunk/NEWS
   trunk/Version.config
   trunk/doc/release_notes.xml
   trunk/extensions/upgradeable_versions.mk
Modified: trunk/ChangeLog
--- trunk/ChangeLog	2019-10-11 13:24:03 UTC (rev 17906)
+++ trunk/ChangeLog	2019-10-13 02:57:29 UTC (rev 17907)
@@ -1,3 +1,239 @@
+2019-10-11 13:24  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17906] liblwgeom/lwin_wkb.c: Memory leak in
+	  lwpoly_from_wkb_state
+	  References #4535
+2019-10-10 17:28  Regina Obe <lr at pcorp.us>
+	* [r17905] doc/po/ja/release_notes.xml.po: manual fix release note
+	  dates and numbers
+2019-10-10 16:58  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17904] NEWS, liblwgeom/cunit/cu_in_wkb.c, liblwgeom/lwin_wkb.c:
+	  WKB: Avoid buffer overflow
+	  This only happens when not running under PG context, as
+	  lwerror continues execution and that means that even after
+	  detecting there isn't enough bytes still try to read from the
+	  buffer
+	  Closes #4535
+	  Closes https://github.com/postgis/postgis/pull/495
+2019-10-10 13:01  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17900] NEWS, liblwgeom/cunit/cu_in_wkt.c,
+	  liblwgeom/lwin_wkt_parse.c, liblwgeom/lwin_wkt_parse.h,
+	  liblwgeom/lwin_wkt_parse.y: Fix leak in WKT collection parser
+	  References #4537
+2019-10-10 11:09  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17893] NEWS, liblwgeom/cunit/cu_in_wkb.c, liblwgeom/lwin_wkb.c:
+	  Fix leak in lwcollection_from_wkb_state
+	  Closes #4536
+	  Closes https://github.com/postgis/postgis/pull/493
+2019-10-10 10:10  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17892] NEWS, liblwgeom/cunit/cu_in_wkb.c,
+	  liblwgeom/lwcurvepoly.c, liblwgeom/lwin_wkb.c: Fix leak in
+	  lwcurvepoly_from_wkb_state
+	  Closes #4534
+	  Closes https://github.com/postgis/postgis/pull/492
+2019-10-08 11:48  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17891] configure.ac, liblwgeom/lwin_geojson.c,
+	  postgis/lwgeom_in_geojson.c, postgis_config.h.in: Remove
+	  HAVE_LIBJSON_C
+	  Patch by jabakobob
+	  References #4528
+2019-10-08 11:40  Sandro Santilli <strk at kbt.io>
+	* [r17890] extensions/address_standardizer/Makefile.in,
+	  extensions/postgis/Makefile.in,
+	  extensions/postgis_raster/Makefile.in,
+	  extensions/postgis_sfcgal/Makefile.in,
+	  extensions/postgis_tiger_geocoder/Makefile.in,
+	  extensions/postgis_topology/Makefile.in: Make sure "make clean"
+	  really cleans what's created by "make"
+	  Fixes #4531 and simplifies a little bit those Makefiles
+2019-10-08 10:59  Sandro Santilli <strk at kbt.io>
+	* [r17889] regress/core/regress.sql,
+	  regress/core/regress_brin_index.sql,
+	  regress/core/regress_brin_index_3d.sql,
+	  regress/core/regress_brin_index_geography.sql,
+	  regress/core/regress_index.sql,
+	  regress/core/regress_index_nulls.sql, regress/core/subdivide.sql:
+	  Allow running core tests from any directory
+	  Using the :regdir variable
+2019-10-08 09:43  Sandro Santilli <strk at kbt.io>
+	* [r17888] regress/run_test.pl: Force using systemwide scripts when
+	  run with --extension
+	  .. rather than relying on version mismatch (current vs.
+	  requested)
+	  to tell where to pick scripts from ..
+	  *might* relate to #4515
+2019-10-08 06:16  Regina Obe <lr at pcorp.us>
+	* [r17887] Version.config, extensions/upgradeable_versions.mk: Flip
+	  to 3.0.0rc2dev
+2019-10-08 06:11  Regina Obe <lr at pcorp.us>
+	* [r17885] ChangeLog, ci/winnie/package_postgis.sh: Change to
+	  package 3.8.0rc2 for windows, prepare for 3.0.0rc1 release
+2019-10-08 00:48  Regina Obe <lr at pcorp.us>
+	* [r17884] doc/po/es/extras_topology.xml.po,
+	  doc/po/fr/reference_accessor.xml.po: Fix pos for spanish and
+	  french so they produce proper XML
+	  Closes #4525
+2019-10-07 23:04  Regina Obe <lr at pcorp.us>
+	* [r17883] HOWTO_RELEASE: Add step to pull translations from
+	  transifex
+	  References #4525
+2019-10-07 22:58  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17882] regress/run_test.pl: Remove view testing from upgrade
+	  objects testing
+	  References #4386
+2019-10-07 22:49  Regina Obe <lr at pcorp.us>
+	* [r17881] doc/po/de/reference_exception.xml.po,
+	  doc/po/es/extras.xml.po,
+	  doc/po/es/extras_address_standardizer.xml.po,
+	  doc/po/es/extras_historytable.xml.po,
+	  doc/po/es/extras_tigergeocoder.xml.po,
+	  doc/po/es/extras_topology.xml.po, doc/po/es/faq.xml.po,
+	  doc/po/es/faq_raster.xml.po, doc/po/es/installation.xml.po,
+	  doc/po/es/introduction.xml.po, doc/po/es/performance_tips.xml.po,
+	  doc/po/es/postgis.xml.po, doc/po/es/reference.xml.po,
+	  doc/po/es/reference_accessor.xml.po,
+	  doc/po/es/reference_bbox.xml.po,
+	  doc/po/es/reference_cluster.xml.po,
+	  doc/po/es/reference_constructor.xml.po,
+	  doc/po/es/reference_editor.xml.po,
+	  doc/po/es/reference_guc.xml.po, doc/po/es/reference_input.xml.po,
+	  doc/po/es/reference_lrs.xml.po,
+	  doc/po/es/reference_management.xml.po,
+	  doc/po/es/reference_measure.xml.po,
+	  doc/po/es/reference_operator.xml.po,
+	  doc/po/es/reference_output.xml.po,
+	  doc/po/es/reference_processing.xml.po,
+	  doc/po/es/reference_raster.xml.po,
+	  doc/po/es/reference_relationship.xml.po,
+	  doc/po/es/reference_sfcgal.xml.po,
+	  doc/po/es/reference_srs.xml.po,
+	  doc/po/es/reference_trajectory.xml.po,
+	  doc/po/es/reference_transaction.xml.po,
+	  doc/po/es/reference_transformation.xml.po,
+	  doc/po/es/reference_troubleshooting.xml.po,
+	  doc/po/es/reference_type.xml.po,
+	  doc/po/es/reference_validation.xml.po,
+	  doc/po/es/reference_version.xml.po,
+	  doc/po/es/release_notes.xml.po, doc/po/es/reporting.xml.po,
+	  doc/po/es/using_postgis_app.xml.po,
+	  doc/po/es/using_postgis_dataman.xml.po,
+	  doc/po/es/using_raster_dataman.xml.po, doc/po/fr/extras.xml.po,
+	  doc/po/fr/extras_address_standardizer.xml.po,
+	  doc/po/fr/extras_historytable.xml.po,
+	  doc/po/fr/extras_tigergeocoder.xml.po,
+	  doc/po/fr/extras_topology.xml.po, doc/po/fr/faq.xml.po,
+	  doc/po/fr/faq_raster.xml.po, doc/po/fr/installation.xml.po,
+	  doc/po/fr/introduction.xml.po, doc/po/fr/performance_tips.xml.po,
+	  doc/po/fr/postgis.xml.po, doc/po/fr/reference.xml.po,
+	  doc/po/fr/reference_accessor.xml.po,
+	  doc/po/fr/reference_bbox.xml.po,
+	  doc/po/fr/reference_cluster.xml.po,
+	  doc/po/fr/reference_constructor.xml.po,
+	  doc/po/fr/reference_editor.xml.po,
+	  doc/po/fr/reference_guc.xml.po, doc/po/fr/reference_input.xml.po,
+	  doc/po/fr/reference_lrs.xml.po,
+	  doc/po/fr/reference_management.xml.po,
+	  doc/po/fr/reference_measure.xml.po,
+	  doc/po/fr/reference_operator.xml.po,
+	  doc/po/fr/reference_output.xml.po,
+	  doc/po/fr/reference_processing.xml.po,
+	  doc/po/fr/reference_raster.xml.po,
+	  doc/po/fr/reference_relationship.xml.po,
+	  doc/po/fr/reference_sfcgal.xml.po,
+	  doc/po/fr/reference_srs.xml.po,
+	  doc/po/fr/reference_trajectory.xml.po,
+	  doc/po/fr/reference_transaction.xml.po,
+	  doc/po/fr/reference_transformation.xml.po,
+	  doc/po/fr/reference_troubleshooting.xml.po,
+	  doc/po/fr/reference_type.xml.po,
+	  doc/po/fr/reference_validation.xml.po,
+	  doc/po/fr/reference_version.xml.po,
+	  doc/po/fr/release_notes.xml.po, doc/po/fr/reporting.xml.po,
+	  doc/po/fr/using_postgis_app.xml.po,
+	  doc/po/fr/using_postgis_dataman.xml.po,
+	  doc/po/fr/using_raster_dataman.xml.po, doc/po/pl/extras.xml.po,
+	  doc/po/pl/extras_address_standardizer.xml.po,
+	  doc/po/pl/extras_historytable.xml.po,
+	  doc/po/pl/extras_tigergeocoder.xml.po,
+	  doc/po/pl/extras_topology.xml.po, doc/po/pl/faq.xml.po,
+	  doc/po/pl/faq_raster.xml.po, doc/po/pl/installation.xml.po,
+	  doc/po/pl/introduction.xml.po, doc/po/pl/performance_tips.xml.po,
+	  doc/po/pl/postgis.xml.po, doc/po/pl/reference.xml.po,
+	  doc/po/pl/reference_accessor.xml.po,
+	  doc/po/pl/reference_bbox.xml.po,
+	  doc/po/pl/reference_cluster.xml.po,
+	  doc/po/pl/reference_constructor.xml.po,
+	  doc/po/pl/reference_editor.xml.po,
+	  doc/po/pl/reference_guc.xml.po, doc/po/pl/reference_input.xml.po,
+	  doc/po/pl/reference_lrs.xml.po,
+	  doc/po/pl/reference_management.xml.po,
+	  doc/po/pl/reference_measure.xml.po,
+	  doc/po/pl/reference_operator.xml.po,
+	  doc/po/pl/reference_output.xml.po,
+	  doc/po/pl/reference_processing.xml.po,
+	  doc/po/pl/reference_raster.xml.po,
+	  doc/po/pl/reference_relationship.xml.po,
+	  doc/po/pl/reference_sfcgal.xml.po,
+	  doc/po/pl/reference_srs.xml.po,
+	  doc/po/pl/reference_trajectory.xml.po,
+	  doc/po/pl/reference_transaction.xml.po,
+	  doc/po/pl/reference_transformation.xml.po,
+	  doc/po/pl/reference_troubleshooting.xml.po,
+	  doc/po/pl/reference_type.xml.po,
+	  doc/po/pl/reference_validation.xml.po,
+	  doc/po/pl/reference_version.xml.po,
+	  doc/po/pl/release_notes.xml.po, doc/po/pl/reporting.xml.po,
+	  doc/po/pl/using_postgis_app.xml.po,
+	  doc/po/pl/using_postgis_dataman.xml.po,
+	  doc/po/pl/using_raster_dataman.xml.po: update rest of pos
+2019-10-07 17:32  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17879] postgis/postgis_before_upgrade.sql: Try and be a little
+	  broader in dropping temporary old signature
+	  References #4521
 2019-10-07 11:41  Raúl Marín Rodríguez <rmrodriguez at carto.com>
 	* [r17878] configure.ac: Fix lib detection with "--with-jsondir"
Modified: trunk/NEWS
--- trunk/NEWS	2019-10-11 13:24:03 UTC (rev 17906)
+++ trunk/NEWS	2019-10-13 02:57:29 UTC (rev 17907)
@@ -1,5 +1,5 @@
 PostGIS 3.0.0rc2
-2019/10/XX
+2019/10/13
 For full changes and enhancements, refer to PostGIS 3.0.0.
 This version requires PostgreSQL 9.5+-12 and GEOS >= 3.6+
Modified: trunk/Version.config
--- trunk/Version.config	2019-10-11 13:24:03 UTC (rev 17906)
+++ trunk/Version.config	2019-10-13 02:57:29 UTC (rev 17907)
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=0
-POSTGIS_MICRO_VERSION=0rc2dev
+POSTGIS_MICRO_VERSION=0rc2
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
Modified: trunk/doc/release_notes.xml
--- trunk/doc/release_notes.xml	2019-10-11 13:24:03 UTC (rev 17906)
+++ trunk/doc/release_notes.xml	2019-10-13 02:57:29 UTC (rev 17907)
@@ -3,6 +3,24 @@
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
     <sect1>
+      <title>Release 3.0.0rc2</title>
+      <para>Release date: 2019/10/13</para>
+      <para>If compiling with PostgreSQL+JIT, LLVM >= 6 is required</para>
+      <para>Supported PostgreSQL versions for this release are:
+      PostgreSQL 9.5 - PostgreSQL 12
+      GEOS >= 3.6. Additional features enabled if you running Proj6+ and/or PostgreSQL 12.
+      Performance enhancements if running GEOS 3.8+</para>
+      <simplesect>
+        <title>Major highlights</title>
+            <para>4534, Fix leak in lwcurvepoly_from_wkb_state (Raúl Marín)</para>
+            <para>4536, Fix leak in lwcollection_from_wkb_state (Raúl Marín)</para>
+            <para>4537, Fix leak in WKT collection parser (Raúl Marín)</para>
+            <para>4535, WKB: Avoid buffer overflow (Raúl Marín)</para>
+      </simplesect>
+    </sect1>
+    <sect1>
       <title>Release 3.0.0rc1</title>
       <para>Release date: 2019/10/08</para>
Modified: trunk/extensions/upgradeable_versions.mk
--- trunk/extensions/upgradeable_versions.mk	2019-10-11 13:24:03 UTC (rev 17906)
+++ trunk/extensions/upgradeable_versions.mk	2019-10-13 02:57:29 UTC (rev 17907)
@@ -58,5 +58,5 @@
 	3.0.0alpha3 \
 	3.0.0alpha4 \
 	3.0.0beta1 \
-	3.0.0beta2dev \
-	3.0.0rc1
+	3.0.0rc1 \
+	3.0.0rc2dev
