[postgis-tickets] [PostGIS] #4541: ST_ConcaveHull returns a "geometrycollection" type instead of the expected "polygon"
trac at osgeo.org
Sun Oct 13 03:21:41 PDT 2019
"polygon"
Reporter: v89461 | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.4
Component: postgis | Version: 2.5.x
Keywords: |
Ran into an unexpected behaviour of `ST_ConcaveHull` during a migration
from 2.4 to 2.5.
The [https://postgis.net/docs/ST_ConcaveHull.html documentation] doesn't
specify the geometry type it returns but I assume it is a `POLYGON`.
Using `POSTGIS="2.4.5 r16765" PGSQL="96" GEOS="3.6.3-CAPI-1.10.3 80c13047"
PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 1.9.2, released 2012/10/08"
LIBXML="2.7.6" LIBJSON="0.11" RASTER`
With the attached `ST_ConcaveHull` query I get a `POLYGON` result, as
expected.
Using `POSTGIS="2.5.2 r17328" [EXTENSION] PGSQL="110"
GEOS="3.7.0-CAPI-1.11.0 673b9939" PROJ="Rel. 5.2.0, September 15th, 2018"
GDAL="GDAL 2.3.1, released 2018/06/22" LIBXML="2.9.1" LIBJSON="0.12"
LIBPROTOBUF="1.3.0" RASTER`
With the attached `ST_ConcaveHull` query I get a strange
`GEOMETRYCOLLECTION` made of several `POINT` and ending with a `POLYGON`.
Maybe it is a string length issue because I get a `POLYGON` as expected if
I remove the first or last point of the query, or if I "round" the values
by removing the `00000001` floating point approximations.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4541>
